Macro - Ilogic - Which is the best opton.
I am have trouble switching my brain over to inventor after switching from Solidworks.
I need something very simple, we have 50,000 parts that will not migrate using the task scheduler so wer are manually opening up a handful than go throught the "rebuild" "save" and "close"
Does anyone have the cose that I could run on all open files -  Rebuild-Save and Close
Some of these files go back to Beta6  :slightly_smiling_face:
A little Help qould be great.
Thanks in advance
and this Invenotr stuff is a little more stable than SW at the moment.
Replies (12)
MechMachineMan
If you get code or make it, it will be something super easy like:
HOWEVER, this will go through every document that is visibly open. Erase '.VisibleDocuments' for it to go through all of them.
I haven't tested this, but it should work for you.
Dim oDoc As Document
For Each oDoc in ThisApplication.Documents.VisibleDocuments
If
With oDoc
         ' .Activate
          .Rebuild
          .Save
          .Close
End with
Next
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
MechMachineMan
It might require a few runs by the time it works its way up to the top level as it wont necessarily start at the bottom level documents, as it is coded.
Justin K
Only need it for single .ipt files. The plan was to open say 20 or 30 at a time.
Sent from my iPhone
MechMachineMan
The .visibledocuments should accomplish that.
Justin K
MechMachineMan
Simply reading things usually goes a long way in programming;
Ran that code.
The error stack that came back:
Error on Line 2 : 'If' must end with a matching 'End If'.
Error on Line 2 : Expression expected.
 Oh heyyyy. Look, the code doesn't have a matching End If/ The If that is there is useless, so delete it.
With oDoc
         ' .Activate
          .Rebuild
          .Save
          .Close
End With
Next
 And then....
Catastrophic failure (Exception from HRESULT: 0x8000FFFF (E_UNEXPECTED))
System.Runtime.InteropServices.COMException (0x8000FFFF): Catastrophic failure (Exception from HRESULT: 0x8000FFFF (E_UNEXPECTED))
   at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
   at Inventor.AttributeSet.get_Name()
   at iLogic.RuleStorage.RuleInDocumentForEqualsTest.GetHashCode()
   at System.Collections.Generic.ObjectEqualityComparer`1.GetHashCode(T obj)
   at System.Collections.Generic.HashSet`1.InternalGetHashCode(T item)
   at System.Collections.Generic.HashSet`1.Remove(T item)
   at iLogic.RuleAndTriggeredEval.EvalRule()
   at iLogic.RuleEditAndRun.RuleEvaluate(RuleEvalContainer ruleEvalCont)
   at iLogic.EditRuleRunner.RuleModifyAndEval(ILmiRule ruleNodeDef, Boolean& cancelled)
 So yeah something bigger actually is wrong. But it still runs the rebuild/save part. It just doesn't like closing files.
Justin K
Thanks for the direction,its working but it works on .ipt files only
MechMachineMan
Hmmm. Could need .Save2(True) or .Rebuild2(True) instead of their counterparts.
Justin K
I have done close to 5,000 ipt files this morning, but I was given a list of assemblies too.
I will need something, but thanks for your input at lunch hour I am going to re-post the code her so others may use.
Ilogic for Rebuild and Save all .ipt Files
With oDoc
         ' .Activate
         .Rebuild
         .Save
         .Close
End With
Next
Stil cant figure out why it wont with assembly or drawing files.
Any clue
MechMachineMan
you could always try the below to see if it works with assemblies, and just use they keyboard shortcut to access the iTrigger.
Alt + G + J + K + T + R
trigger=iTrigger0
Dim oDoc As Document = ThisApplication.ActiveDocument
With oDoc
' .Activate
.Rebuild
.Save
.Close
End With
Justin K
MechMachineMan
Also, Rebuild does not work on drawing files. Best you can do it .Update. Which might be what fixes the other issue for you anyways.
so
If oDoc.DocumentType() = kAssemblyDocumentObject Or kDrawingDocumentObject
With oDoc
         ' .Activate
         '.Rebuild
         .Update
         .Save
         .Close
End With
Else
With oDoc
         ' .Activate
         .Rebuild
         '.Update
         .Save
         .Close
End With
End if
Next
Justin K
