Logical type of Active Inv Doc (if TryCast is a best bet)
Maxim-CADman77
Maxim-CADman77
I'm playing around with iLogic trying to find best way to get logical type of active document.
I mean those logical types:
3D-models
  • Generic Part
  • Generic Assembly
  • Generic Drawing
  • iPart Factory
  • iPart Member
  • iAssy Factory
  • iAssy Member
2D-drawings
  • Generic Drawing (not based on any 3D-model)
  • Exploded View Drawing
  • (Single) Part Drawing
  • (Single) Assembly Drawing
  • Multi-configuration Part Drawing (based on iPart Member or iPart Factory)
  • Multi-configuration Assembly Drawing (based on iAssy Member or iAssy Factory)
I 've achieved my goal to about 75%. There are problems with Generic Drawing (object not set to an instance of an object) and both multi-config drawings (I'm a bit confused by depth of object tree and can't find how to get object types for i- factories and members).
My current version of code is:
Dim partDoc As PartDocument = TryCast(ThisDoc.Document, PartDocument)
Dim assyDoc As AssemblyDocument = TryCast(ThisDoc.Document, AssemblyDocument)
Dim drwDoc As DrawingDocument = TryCast(ThisDoc.Document, DrawingDocument)
Dim MsgBody As String
If (partDoc IsNot Nothing) Then
	oCompDef=partDoc.ComponentDefinition
	If (oCompDef.iPartFactory IsNot Nothing) Then
		MsgBody="iPart Factory"
	Else If (oCompDef.iPartMember IsNot Nothing) Then
		MsgBody="iPart Member"
	Else
		MsgBody="Generic Part"
	End If
Else If (assyDoc IsNot Nothing) Then
	oCompDef=assyDoc.ComponentDefinition
	If (oCompDef.iAssemblyFactory IsNot Nothing) Then
		MsgBody="iAssy Factory"
	Else If (oCompDef.iAssemblyMember IsNot Nothing) Then
		MsgBody="iAssy Member"
	Else
		MsgBody="Generic Assembly"
	End If
Else If (drwDoc IsNot Nothing) Then
	Dim ModelExt As String = TryCast (IO.Path.GetExtension(ThisDrawing.ModelDocument.FullFileName).ToLower, String)
	If ModelExt=".ipn" Then
		MsgBody="Exploded view drawing"
	Else If ModelExt=".ipt" Then
		MsgBody="Part drawing"
		' If ??? Then MsgBody="Multi-config Part drawing"
	Else If ModelExt=".iam" Then
		MsgBody="Assembly drawing"
		' If ??? Then MsgBody="Multi-config Assy drawing"
	Else
		MsgBody="Generic Drawing"
	End If
Else
	MsgBody="UnknownDoc"
End If
MsgBox (MsgBody,,"Type of active doc is:")
Can somebody help me with this, please
Please vote for Inventor-Idea Text Search within Option Names
Replies (8)
clutsa
Would any of this info help you?
Sub Test()
Dim app As Application
Dim Doc As Document
Dim CompDef As ComponentDefinition
Dim PartType As String
Set app = ThisApplication
Set Doc = app.ActiveDocument
Set CompDef = Doc.ComponentDefinition
iPartFac = CompDef.IsiPartFactory
iPartMem = CompDef.IsiPartMember
Select Case Doc.DocumentType
Case Is = DocumentTypeEnum.kPartDocumentObject
    PartType = "Part File"
Case Is = DocumentTypeEnum.kDrawingDocumentObject
    PartType = "Drawing File"
'Case Is .... keep going with these
End Select
End Sub
Those may be easier then what you're doing.
I know you'll have to have some error trapping but that should be a good start.
If I've helped you, please help me by supporting this idea.
Mass Override for Each Model State
Custom Glyph Icon for iMates
clutsa
This will probably match more to what you had started.
Sub Test()
Dim Doc As Document
    MsgBody = "Part File"
    If CompDef.IsiPartFactory Then MsgBody = "Multi-config Part Factory"
    If CompDef.IsiPartMember Then MsgBody = "Multi-config Part Member"
    MsgBody = "Plain Drawing File"
    Dim DocM As Document
    Set DocM = Doc.ReferencedDocuments.Item(1)
    Set CompDef = DocM.ComponentDefinition
    Select Case DocM.DocumentType
        MsgBody = "Part Drawing File"
        If CompDef.IsiPartFactory Then MsgBody = "Multi-config Part drawing Factory"
        If CompDef.IsiPartMember Then MsgBody = "Multi-config Part drawing Member"
    Case Id = DocumentTypeEnum.kAssemblyDocumentObject
        MsgBody = "Assy Drawing File"
        If CompDef.IsiPartFactory Then MsgBody = "Multi-config Assy drawing Factory"
        If CompDef.IsiPartMember Then MsgBody = "Multi-config Assy drawing Member"
    End Select
Case Is = DocumentTypeEnum.kAssemblyDocumentObject
    MsgBody = "Assy File"
    If CompDef.IsiAssemblyFactory Then MsgBody = "Multi-config Assy Factory"
    If CompDef.IsiAssemblyMember Then MsgBody = "Multi-config Assy Member"
End Select
MsgBox (MsgBody)
End Sub
Maxim-CADman77
Thanks. The only weak place - attempt to execute this on empty (without reference to 3Dmodel) drawing -
Run-time error '5': Invalid procedure call or argument.
How would you recommend to treat such errors?
clutsa
Sub Test()
Dim Doc As Document
    If Doc.ReferencedDocuments.Count > 0 Then
        End Select
    End If
End Select
MsgBox (MsgBody)
End Sub
Maxim-CADman77
shame on me ...
Maxim-CADman77
Extensive testing revealed issues with Assy Drawing
If replace "Id" with "Is" then "Public member 'IsiPartFactory' on type 'AssemblyComponentDefinition' not found." :disappointed_face:
Maxim-CADman77
Got it - should be:
Sub Test()
Dim Doc As Document
Case DocumentTypeEnum.kPartDocumentObject
Case DocumentTypeEnum.kDrawingDocumentObject
        Case DocumentTypeEnum.kAssemblyDocumentObject
            If CompDef.IsiAssemblyFactory Then MsgBody = "Multi-config Assy drawing Factory"
            If CompDef.IsiAssemblyMember Then MsgBody = "Multi-config Assy drawing Member"
        End Select
    End If
End Select
MsgBox (MsgBody)
End Sub
Anyway solution is yours.. Thanks!
clutsa
Oops. I caught it in the assembly section itself but missed it in the drawing/assembly section. Sorry. Thank you for the solution and posting the correct code.
