Locating Planes In Drawing View
Tiffany_Hayden_
Tiffany_Hayden_
I have code that finds the planes in model space and I have converted it over to drawing space using (oDrawView.ModelToDrawingViewSpace) but it doesn't seem to translate correctly. When I find the farthest curves in the drawing view the planes that should exist in the drawing views are way too large. I'm just wandering if I'm doing it right and if anyone has any tips to locate planes in a drawing view would be very helpful! Thanks in advance!
    For Each oOcc In oAssyDoc.ComponentDefinition.Occurrences
        If oOcc.BOMStructure = kReferenceBOMStructure Then
            Set oSubOccs = oOcc.Definition.Occurrences
            For Each oSubOcc In oSubOccs
                If InStr(oSubOcc.Name, "Floor") Or InStr(oSubOcc.Name, "FLOOR") Then
                    Set oSubDef = oSubOcc.Definition
                    For Each oWPlane In oSubDef.WorkPlanes
                        If oWPlane.Name <> "XY Plane" And oWPlane.Name <> "YZ Plane" And oWPlane.Name <> "XZ Plane" Then
                            Set oWPlaneProxy = GetWPlProxy(oSubOcc, oWPlane)
                            Set oSubOccPt2D = oDrawView.ModelToDrawingViewSpace(oWPlaneProxy.Plane.RootPoint)
                            Debug.Print oWPlaneProxy.Name & "-" & oSubOccPt2D.X & ", " & oSubOccPt2D.Y
                        End If
                    Next
                End If
            Next
        End If
    Next
Tiffany Hayden
Tiffany_Hayden_
Trick was using ModelToSheetSpace instead of ModelToDrawingViewSpace. Now I'm getting very close values.
Tiffany Hayden
