Announcements
Linear dimension using two work points
ysbaodnj
ysbaodnj
We want to represent a dimension using two points.
However, if two points are not collinear, as shown below, the dimensions are displayed diagonally.
Is it possible to make these two points appear unconditionally in linear dimensions as shown in the picture below?
JMGunnar
You can use
DimensionTypeEnum.kHorizontalDimensionType
	Dim linDimA1 = genDims.AddLinear("DimensionA1", DimPos, StartBottomPoint, EndBottomPoint,DimensionTypeEnum.kHorizontalDimensionType,dimensionStyle := ds)
Best Regards Johan Gunnar
JMGunnar
	Class ThisRule
		''SetDimensionPositions("view")
		Dim viewCenter As Point2d
		Dim leftView As Double
		Dim rightView As Double
		Dim belowView As Double
		Dim overView As Double
		Dim viewCenterX As Double
		Dim viewCenterY As Double
		Dim currentDim As GeneralDimension
		Sub Main()
			Dim ds As DimensionStyle = ThisDrawing.Document.StylesManager.DimensionStyles.Item(oDimensionStyles)
			Dim genDims =  ActiveSheet.DrawingDimensions.GeneralDimensions
			''''Sheet 1
			 	ActiveSheet = ThisDrawing.Sheet("Sheet:2")
			'''Dimension View A
				Dim view_A = ActiveSheet.DrawingViews.ItemByName("A")
				oView = ActiveSheet.View("A").View
			'''Get Position of View
				SetDimensionPositions("A")
				LeftPoint = view_A.GetIntent({"MasterTank" }, "LeftPoint")
				RightPoint = view_A.GetIntent({"MasterTank" }, "RightPoint")
				''Set Dimension
					DimPos = ThisDrawing.Geometry.Point2d(0, belowView-10)
				Dim linDimA1 = genDims.AddLinear("DimensionA1", DimPos, LeftPoint, EndBottomPoint,RightPoint.kHorizontalDimensionType,dimensionStyle := ds)
		End Sub
		Sub SetDimensionPositions(viewName As String)
			viewCenter = ActiveSheet.View(viewName).View.Center
			leftView = viewCenter.X*10 - ActiveSheet.View(viewName).Width / 2
			rightView = viewCenter.X*10 + ActiveSheet.View(viewName).Width / 2
			belowView = viewCenter.Y*10 - ActiveSheet.View(viewName).Height / 2
			overView = viewCenter.Y * 10 + ActiveSheet.View(viewName).Height / 2
			viewCenterX = viewCenter.X * 10
			viewCenterY = viewCenter.Y * 10
		End Sub
	End Class
ysbaodnj
Thank you for answer! Problem solved 🙂
JMGunnar
Please use Accepted Solutions
then we can see if the problem is solve in the future
@ysbaodnj
see info
https://forums.autodesk.com/t5/forum-user-guides/accepted-solutions-what-they-are-how-to-find-them-a...
Best Regards Johan
