Linear diameter using ilogic
manu.marjanen
manu.marjanen
How to modify this code to create a linear diameter?
Dim Sheet_1 = ThisDrawing.Sheets.ItemByName("Sheet:1")
Dim view_A = Sheet_1.DrawingViews.ItemByName("A")
Dim Face0 = view_A.GetIntent("Part:1", "Face0") 'Part:1 Assign name "Face0"
Dim Z_Axis = view_A.GetIntent("Z Axis") 'Assembly ZAxis
Dim genDims = Sheet_1.DrawingDimensions.GeneralDimensions
Dim linDim1 = genDims.AddLinear("Dimension 1", view_A.SheetPoint(-0.5, 1.05), Face0)
chandra.shekar.g
Autodesk Support
Autodesk Support
@manu.marjanen,
Please refer below forum discussion for creating linear diameter dimension.
https://forums.autodesk.com/t5/inventor-forum/creating-linear-diameter-dimension-using-api/td-p/6238...
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
theo.bot
@manu.marjanen
you just need to add the dimension style to you code:
Dim linDim1 = genDims.AddLinear("Dimension 1", view_A.SheetPoint(-0.5, 1.05), Face0,kDiametricDimensionType)
