it is possible to check if an file is alway open ?
Darkforce_the_ilogic_guy
I have an code da get some data form the model , copy an templete Excel fil , and then open it
My problem is that If i run the code without close the excel the Excel file have the same name as the part numer the code will fail.. that I want it to do is to check if the file is open , and if it is close it before copy the templete and open it again.
is there a way to do this ?
Ralf_Krieg
Hello
You can try following
Add in the Header of your rule
AddReference "Microsoft.Office.Interop.Excel.dll"
Imports Microsoft.Office.Interop
Imports System.Runtime.InteropServices
In your rule add
Dim objApp As Excel.Application= TryCast(Marshal.GetActiveObject("Excel.Application"), Excel.Application)
If objApp IsNot Nothing Then
	Dim objBooks As Excel.Workbooks
	objBooks = objApp.Workbooks
	Dim objBook As Excel._Workbook
	For Each objBook In objBooks
		If objBook.Name= "Document-Name_With-Extension-Without_Path" Then
		'If objBook.FullName= "DocumentName_With-FullPath-and-Extension" Then 'alternative, if document name alone is not specific enough
			objBook.Close
			Exit For
		End If
	Next
End If
R. Krieg
RKW Solutions
www.rkw-solutions.com
