Issue creating a new part file in API
cstephens58F4Q
cstephens58F4Q
Im sure im overlooking something small but I am trying to get a part file created before I edit it with passed variables. The issue Im having is the line below is giving me the error "Error BC30469 Reference to a non-shared member requires an object reference. "
Dim oDoc As PartDocument = Documents.Add(DocumentTypeEnum.kPartDocumentObject, oTemplatesPath & "standard.ipt", False)
Below is this full portion of code:
Public Sub CreateStandardPart(x_length As Double, y_length As Double, z_length As Double, loc As String, oPath As String)
        'Create a new part with your desired part template
        Dim oProjectMgr As DesignProjectManager
        Dim oProject As DesignProject
        oProject = oProjectMgr.ActiveDesignProject
        Dim oTemplatesPath As String
        oTemplatesPath = oProject.TemplatesPath
        oDoc.OpenFile()
        oDoc.SaveAs(loc & oPath, True)
        oDoc.Close(False)
    End Sub
 Let me know if you have any ideas. Thanks
WCrihfield
Hi @cstephens58F4Q.  It looks like you are missing the step where you set a value to your oProjectMgr variable.  Try this:
Dim oProjectMgr As DesignProjectManager = ThisApplication.DesignProjectManager
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) :thumbs_up:.
Wesley Crihfield
(Not an Autodesk Employee)
cstephens58F4Q
Thanks for the quick anwser I knew it was something simple I overlooked
cstephens58F4Q
@WCrihfield again on this section of code. Any reason you could see why I would be getting the attached error in this line of code: oDoc.SaveFileAs(oPath & loc)
error:
System.MissingMemberException: 'Public member 'SaveFileAs' on type '_DocumentClass' not found.'
Issue area:
        MsgBox("here with x length = " & x_length)
        'Dim oApp As Class = g_inventorApplication
        Dim oProjectMgr As DesignProjectManager = g_inventorApplication.DesignProjectManager
        Dim oDoc As PartDocument = g_inventorApplication.Documents.Add(DocumentTypeEnum.kPartDocumentObject, oTemplatesPath & "/English/OC Standard.ipt", True)
        oDoc.Activate()
    End Sub
Here is how I am calling out oPath:
SaveFileDialog1.Filter = "Assembly|*.iam"
        SaveFileDialog1.InitialDirectory = "C:\Temp"
        SaveFileDialog1.Title = "Save Melter Model"
        SaveFileDialog1.ShowDialog()
        If SaveFileDialog1.FileName IsNot "" Then
            SaveFileDialog1.OpenFile()
            oFile = SaveFileDialog1.FileName
        End If
        ''Sets directory for future use
        Dim oPath_ As String = oFile
        Dim oPat As Integer = InStrRev(oPath_, "\")
        Dim oPath As String = Mid(oPath_, 1, oPat)
tyler.warner
Try this instead:
Inventor help link here.
oDoc.SaveAs(oPath & loc, False)
If this solved your problem or answered your question, please click ACCEPT SOLUTION.
If this helped you, please click LIKE.
cstephens58F4Q
Yeah tried that same error
tyler.warner
Try this one & see if you're still getting the error. I changed the name & path variables slightly because I wasn't sure what was being entered into the Sub. This will overwrite the file in the specified folder if it already exists, so you'd have to write a check if you don't want that to be the case.
    Dim oFileName As String = "Save Melter Model.ipt"
    Dim oFilePath As String = "C:\Temp\"
    Dim oProject As DesignProject = oProjectMgr.ActiveDesignProject
    Dim oTemplatesPath As String = oProject.TemplatesPath
    Try
        oDoc.SaveAs(oFilePath + oFileName, False)
    Catch ex As Exception
        MsgBox("Copy didn't work!.... see error message below:" & vbNewLine & ex.Message)
        Exit Sub
    End Try
End Sub
