Is there any alternate method or features for ifeature creation?
gparamasivam
gparamasivam
Current iFeature problems:
Not possible to update the ifeatures.
Remove the ifeature and then place the new updated ifeatures.
It will be creating more missing issues like dimenions, constraints etc..
Required:
Need to update and replace the ifeatures as like as ipt models
Is it possible?!
Michael.Navara
This is not possible directly (some internal functionality). But you can create the code for looking for iFeature in active model and if it meets some criteria, you can read its inputs and create new one from updated source and delete the old one.
bhavik4244
@gparamasivam
it not possible at the moment.
Since iFeature is consist of several referances like plane, face, sketches so it seems difficult to replace or modify after creation. Moreover, when it deployed on a component you can only able to see the so and so iFeature but won't able see what sort of features it consist of.
Bhavik Suthar
