iProp Wiz Evaluation Expired
Winks87
Winks87
Dont know where to ask this so.... I downloaded the iProp wiz trial, but time expired before I really had time to set it up to show management this is a good tool (sell it to them).  Is there a way to reinstall the trial?  I tried, but it still tells me trial has expired.
James Winkler
MechMachineMan
Have you tried googling the app developer's contact info or looked that up through the app and contacted them directly, rather than all of us on the forums who are unaffiliated with the App?
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Winks87
Site is down I guess...thx for the reply MM
James Winkler
Vladimir.Ananyev
iPropWiz was  published on the Autodesk App Stpre by C-Cubed Technologies Ltd.
"Contact us" information:  neil@c3mcad.com
Please ask them for support.
cheers,
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
