iPart or iAssembly member save as other automation
j.peterszetapdm
j.peterszetapdm
Hi all,
I'm not all that up to speed with iLogic but I've cobbled together a rule to generate all members of an iPart/iAssembly factory. This is good but I really want it to also save as another format too like a .sat file or .step and I cant seem to get it to, it will only save the current member.
' Set reference to active document.
oDoc = ThisApplication.ActiveDocument
' Check the Document type is an assembly or part
If (oDoc.DocumentType <> kAssemblyDocumentObject And _
   oDoc.DocumentType <> kPartDocumentObject) Then
   MsgBox("Error:Document type is not assembly/part")
   Exit Sub
End If
Dim oDef As AssemblyComponentDefinition = oDoc.ComponentDefinition
Dim initRowIndex As Integer
Dim oFactory As iAssemblyFactory = oDef.iAssemblyFactory
Dim oRow As iAssemblyTableRow
For Each oRow In oFactory.TableRows
	' Generate the member and file, (overwrites member file or creates new file)
	oFactory.CreateMember(oRow)
	' Get document's full file name
    sFname = iProperties.Value("Project", "Part Number") & ".sat"
    ' Do a 'Save Copy As' to SAT format
    oDoc.SaveAs(sFname, True)
Next
Anyone able to help get the save as for each member working?
Replies (7)
chandra.shekar.g
Autodesk Support
Autodesk Support
@j.peterszetapdm ,
Hoping that below iLogic code may be helpful to save iAssemblymembers. Similarly, code can be modified for iPart.
   Exit Sub
End If
Dim oMember As iAssemblyMember
	oMember = oFactory.CreateMember(oRow)
Dim oPath As String
oPath = oMember.ParentFactory.MemberCacheDir
Dim oReferDoc As AssemblyDocument oReferDoc = ThisApplication.Documents.Open(oPath & "\" & oRow.MemberName & ".iam", True) Dim oName As String oName = oReferDoc.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value Call oReferDoc.SaveAs(oPath & "\" & oName & ".iam", True)
Call oReferDoc.Close Next
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
j.peterszetapdm
Hi there, thank you for your help. I've had a go with the code but I am getting an error with line 20
"Error on Line 20 : Expression does not produce a value."
Is there something i could be missing?
chandra.shekar.g
Autodesk Support
Autodesk Support
@j.peterszetapdm ,
Actually, previous code is for iAssmeblyFactory. Is code is used for iAssembly or iPart?
If you provide non confidential iAssmebly file, I can simulate error and correct the same.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
j.peterszetapdm
Thank you, attached is the assembly i am trying to export each memeber out as an obj in this case. I could generate all the members with my code but I couldnt figure out how to export each one as well, it just exported the current member.
chandra.shekar.g
Autodesk Support
Autodesk Support
@j.peterszetapdm,
Try this iLogic code for iAssembly.
   Exit Sub
End If
	Call oFactory.CreateMember(oRow)
	Dim oPath As String
	oPath = oFactory.MemberCacheDir
    Dim oName As String
    ThisApplication.SilentOperation = True
	ThisApplication.SilentOperation = False
Next
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
j.peterszetapdm
Thats got it thank you.
Andrey.Subbotin
Dear colleagues,
Could you please help us with such question: we are using oFactory.CreateMember method
for processing and saving Assemblymembers (we are using Inventor API to create our own add-in for Inventor), but we use C#. And we get an error, cause it doesn't work. Could you please tell us if this method (oFactory.CreateMember) also could be used for C# or maybe there are some other methods for C#?
