Inventor SDK thickness analysis
Hi
Is it possible to run a thickness analysis on a part through the SDK? Ideally, could all faces that are less than a certain thickness be identified through the SDK?
JDMather
Is there a reason you can't use the section analysis - I am thinking that what you need is already built into the software but that you might not be aware of it.
JDMather
Do you need a tool more sophisticated than this?
If you have Inventor Professional - I think there might also be a relevant tool within the Mold Design environment.
But could this be invoked through the SDK?
mcgyvr
So you want to run this in batches or without having to manually perform the task in Inventor right?
Yes, that's right. I'm hoping to automate checking / validation (as much as possible), essentially.
