Inventor rule to change mm^2 to m^2
gregor.leban
gregor.leban
I write a rule:
iProperties.Value("Custom", "AreaM2") = Round(iProperties.Area / 1000000,2)
That part is working.
However, in drawing I only get numbers. I would like to get a unit as well (and not writing it manually).
Perhaps is a dumb question, but I just can't figure it out...
(Inventor 2020)
Replies (7)
Hello @gregor.leban . You can format your titleblock or just add text with format. Please see the snapshot.
gregor.leban
Is it possible to have that write in code, like here with Mass :
Add something at the end.
iProperties.Value("Custom", "AreaM2") = Round(iProperties.Area / 1000000,2) & " m^2"
gregor.leban
Thank you!
I have the same code for volume:
iProperties.Value("Custom", "VolumeM3") = Round(iProperties.Volume / 1000000000,5) & " m^3"
But here something weird happens when I add  your solution at the end...
It transforms result from 0,00004 to 4E-05
Why?
It works fine here. That "E" , I think it means something cannot be displayed like may its too long. Try with smaller part.
gregor.leban
Yes, with bigger part it is working normally but with smaller it display that E-.
Wonder why.
with 1mm x 10mm part, i got the same.
Maybe you can use less decimal, but you will probably get zero value. So, maybe better not use  m^3.
