Announcements
Inventor multivalue parameter in iLogic form
I'm trying to make Inventor Form from which I can control a multivalue parameter. The parameter is linked to another parameters to define the values (I am using pipe sizes DN150...DN800 as primary parameter values and defining values DN150=168,3mm...DN800=813mm). The multivalue is showing as read only in form editor and I can't change the values. How can I fix this?
-umeet
HermJan.Otterman
can you share you test project?
thanks
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
