Inventor iLogic: Auto-Retrieving 3D Annotations from Part Templates into Assembly Drawing Views
Anthony5375F
Message 1 of 10
Anthony5375F
Hello all,
I am currently working on an iLogic rule in Autodesk Inventor that aims to automatically retrieve and display 3D annotations (specifically dimensions) from part templates when these parts are used within an assembly. These annotations should automatically appear in the drawing views of that assembly.
The goal is to pre-add dimensions in template parts, and when creating a detailed drawing of a model state containing multiple parts, these dimensions should appear automatically.
Here is the scenario:
  1. I have template part files with 3D annotations.
  2. These parts are placed into an assembly.
  3. I create a drawing of this assembly.
  4. I want an iLogic rule that, when run, retrieves the 3D annotations from the parts and shows them in the assembly drawing view.
I have tried several iterations of code, but have been facing various challenges related to the API methods I'm trying to use. Here's a snippet of the latest version:
Sub Main
Dim oView As DrawingView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select a view")
If oView Is Nothing Then Exit Sub
Dim refDoc As Document = oView.ReferencedDocumentDescriptor.ReferencedDocument
If refDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
Dim oPartDoc As PartDocument = refDoc
RetrieveDimensionsFromPart(oPartDoc, oView)
End If
End Sub
Sub RetrieveDimensionsFromPart(oPartDoc As PartDocument, oView As DrawingView)
Dim dimCollection As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
For Each oAnnotation As ModelAnnotation In oPartDoc.ComponentDefinition.ModelAnnotations
If TypeOf oAnnotation Is ModelDimension Then
dimCollection.Add(oAnnotation)
End If
Next
' Retrieve the dimensions into the drawing view
oView.Parent.DrawingDimensions.GeneralDimensions.Retrieve(oView, dimCollection)
End Sub
Errors and issues encountered:
  • Initially, there were type-related errors, such as 'Annotations' not being defined.
  • Following that, I ran into challenges with members like 'DrawingDimensions' and 'ModelDimensions' not being found.
  • Lastly, the rule runs without errors, but no annotations are retrieved/displayed in the drawing view.
I would greatly appreciate any insights, suggestions, or corrections from anyone familiar with this process or who has tackled similar challenges. I'm sure I'm missing something fundamental, or perhaps there's an entirely different approach I should consider.
Thank you in advance for your time and expertise!
Replies (9)
Message 2 of 10
WCrihfield
Hi @Anthony5375F.  The first thing I see within your code that does not look correct to me, is that you are expecting the direct model document type referenced by the view to be a part.  According to your task description, the view should be directly referencing an assembly, not a part.  Then the part should be represented by a component within that assembly (or one of the assemblies referenced documents).  And when that is the case, I would assume that you would first need to get the 'proxy' of the part's ModelDimension that is within the context (3D model coordinate space) of the assembly.  Then you could supply that proxy as the input for retrieving dimensions into the view.  Unfortunately, I do not see a ModelDimensionProxy as a valid object Type within Inventor's API Object Model right now (using Inventor Pro 2024.0.1).  I see proxy Types of some of the other ModelAnnotation related objects, but not that one, for some reason.  It may still be possible by not specifying the specific object Type, but I have not tried it yet myself.
Edit:  I did not look deep enough for the proxy type object.  ModelDimension is a base type for several more specific types, such as AngularModelDimension, DiameterModelDimension, LinearModelDimension, & RadiusModelDimension.  Those do have a proxy version (AngularModelDimensionProxy, DiameterModelDimensionProxyLinearModelDimensionProxy, RadiusModelDimensionProxy).
Wesley Crihfield
(Not an Autodesk Employee)
Message 3 of 10
Anthony5375F
Firstly, thank you for your insightful comment regarding my issue. I've tried to implement your suggestions and adapt my code accordingly. However, I'm still facing challenges, particularly around the retrieval of ModelDimensions from parts within an assembly. I've encountered an "Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))" while attempting to access the Occurrences of the ComponentDefinition.
Given your familiarity with Inventor 2024 Pro's API, do you have any further advice or potential solutions for this issue? Here's a snippet of the current code for your reference:
' Loop through each component in the assembly.
For Each oComponent As ComponentOccurrence In oAssemblyDoc.ComponentDefinition.Occurrences
' ... (rest of the code for brevity)
Next
I'm particularly interested in any insights you might have around the potential absence of a ModelDimensionProxy object type in Inventor's API Object Model, and if there's a workaround or alternative method that I might have overlooked.
Anthony5375F
Message 4 of 10
WCrihfield
Hi @Anthony5375F.  I've got to leave, so I sort of threw this together at the last minute, but here is an example iLogic rule you can play around with for the task you are trying to achieve.  It is a bit narrow at the moment, because it only attempts to work with part type components, and only linear model dimensions, but all that can be expanded upon later.  I may check back tomorrow.
Sub Main
	oObj = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select a Drawing View.")
	If IsNothing(oObj) OrElse (TypeOf oObj Is DrawingView = False) Then Exit Sub
	Dim oView As DrawingView = oObj
	Dim oModelDoc As Document = oView.ReferencedDocumentDescriptor.ReferencedDocument
	If oModelDoc.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then Exit Sub
	Dim oADoc As AssemblyDocument = oModelDoc
	Dim oOccs As ComponentOccurrences = oADoc.ComponentDefinition.Occurrences
	If oOccs.Count = 0 Then Exit Sub
	Dim oObjColl As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
	For Each oOcc As ComponentOccurrence In oOccs
		If oOcc.Suppressed Then Continue For
		If TypeOf oOcc.Definition Is VirtualComponentDefinition Then Continue For
		If TypeOf oOcc.Definition Is WeldsComponentDefinition Then Continue For
		Dim oOccDoc As Document = oOcc.Definition.Document
		If oOccDoc.DocumentType <> DocumentTypeEnum.kPartDocumentObject Then Continue For
		Dim oOccPDoc As PartDocument = oOccDoc
		Dim oMAs As ModelAnnotations = oOccPDoc.ComponentDefinition.ModelAnnotations
		If oMAs.Count = 0 Then Continue For
		Dim oMDs As ModelDimensions = oMAs.ModelDimensions
		If oMDs.Count = 0 Then Continue For
		For Each oMD As ModelDimension In oMDs
			If oMD.Type = ObjectTypeEnum.kLinearModelDimensionObject Then
				Dim oLMD As LinearModelDimension = oMD
				Dim oLMDProxy As LinearModelDimensionProxy = Nothing
				oOcc.CreateGeometryProxy(oLMD, oLMDProxy)
				'now the oLMDProxy object is in the context of this component's parent assembly
				oObjColl.Add(oLMDProxy)
			End If
		Next 'oMD
	Next 'oOcc
	Dim oSheet As Inventor.Sheet = oView.Parent
	Dim oGDims As GeneralDimensions = oSheet.DrawingDimensions.GeneralDimensions
	oGDims.Retrieve(oView, oObjColl)
End Sub
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
Message 5 of 10
Anthony5375F
Hi @WCrihfield
Thank you for taking the time to share your iLogic rule. I've been trying to work with it and appreciate the foundation it provides. I noticed your mention of the code being a bit narrow, focusing on LinearModelDimension objects. Based on that hint, I attempted to adapt the rule to consider all dimensions by iterating through ModelDimensions. Here's what I tried:
Sub Main
' Prompt user to pick a drawing view
' Check if a valid view is selected
' Retrieve the document associated with the drawing view
' Check if the document is an assembly type
' Get all component occurrences in the assembly
' Exit if no components are found
' Create a collection to hold dimension proxies
' Loop through each component occurrence in the assembly
' Skip suppressed components
' Skip virtual and weld components
' Get the document associated with the component occurrence
' Continue only if the component document is a part type
' Get all annotations in the part
' Skip components with no annotations
' Loop through each model dimension in the part's annotations
For Each oMD As ModelDimension In oMAs.ModelDimensions
' If the dimension is linear type, create a proxy in the assembly context
' Add the proxy object to the collection
End If
Next 'oMD
Next 'oOcc
' Retrieve dimensions into the drawing view from the collection
End Sub
  1. Have you faced any issues with the oGDims.Retrieve method, or do you know of constraints that might cause this error?
  2. Any best practices or insights when working with model dimensions in Inventor, especially within assembly documents, would be invaluable.
    To give a clearer picture of the issue and setup, I've added images for reference. You can see both the part level and assembly, as well as drawing images.
 Thank you very much and speak soon
Message 6 of 10
Anthony5375F
Hi @WCrihfield,
Thanks for the initial assistance on the iLogic rule. I've been trying to expand upon the rule you provided, but I'm still encountering a few issues. I attached some images in my previous post that might help clarify the situation. Could you possibly take another look when you have some time?
Appreciate your expertise on this matter.
Thank you
Message 7 of 10
EDrew3PS7R
Observer
Observer
@WCrihfield @Anthony5375F
Have either of you been able to solve this problem? I am working on something similar, but nothing I have done has been able to work.
When I try to run the code from Message 4 of 6, I get an 'Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))' Message for line 34.
Any help would truly be appreciated, Thank you
Message 8 of 10
WCrihfield
Hi @EDrew3PS7R.  The good news is that Autodesk has created some new methods specifically for these processes, and they are available to the 2025 and newer versions of Inventor.  Unfortunately though, I am still stuck with 2024.4.1 (employer related 🙄 ) so they are not available to me yet.  Those new methods are listed below, and specifically include documentation about the '3D annotations' (and their proxies), not just dimensional constraints and feature dimensions.
Sheet.GetAvailableDesignViewsToRetrieve3DAnnotations
Sheet.GetRetrievableAnnotations2
Sheet.RetrieveAnnotations2
Wesley Crihfield
Message 9 of 10
EDrew3PS7R
Observer
Observer
@WCrihfield
Unfortunately, I am also stuck with inventor 2024 for the foreseeable future. For the same reasons as you.
Thank you for the help though! I've already started hard dimensioning the assembly using named entities and I'll keep a RetrieveAnnotations script on standby
Message 10 of 10
WCrihfield
OK.  I did not see this mentioned earlier in this conversation, but we do have one more related tool available to us, but it does not solve the problem of 'proxy' 3D annotations from lower level components.  The property (Link below) was added in the 2022 version of Inventor, which made things a bit easier.  Manually, we see that option when we have the Edit DrawingView dialog open, and click on the little gear icon next to the design view representation row.  In that sub menu is 2 options...one for using the camera that was saved in the custom design view, if a custom design view was specified...the other for this option.  But that will only include 3D annotations that were directly created within the document that the view is directly referencing, not ones created within parts that are components of an assembly, where the view references the assembly.  Just something to keep handy in the code toolbox.
DrawingView.Include3DAnnotations
Wesley Crihfield
