Announcements
Inventor half section view Problem
Whenever i try to make a half section view in 2018 version that solid plane appears.
Is that a Bug or a problem in my pc or what ??
Thank you.
HermJan.Otterman
try updating your graphic driver
save you settings: file, options, export
from the start menu, autodesk, inventor run the inventor reset utility
hope this helps
import the settings.
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
