inventor drawing Dimension align to center using ilogic gives error
I was trying to align the drawing dimensions to center but it gives error.
can any one help me out to resolve the error.
My code is mentioned below:
    Dim oDrawDoc As DrawingDocument
    Dim oSheet As Sheet
    oDrawDoc = ThisApplication.ActiveDocument
    oSheet = oDrawDoc.Sheets.Item(1)
    Dim oDimension As DrawingDimension
    oDimension.CenterText
Sergio.D.Suárez
Hi, try this code, center the linear and angular dimensions
Dim oDoc As DrawingDocument = ThisDoc.Document
Dim oSheet As Sheet = oDoc.ActiveSheet
' Iterate over all dimensions in the drawing and center them if they are linear or angular.
For Each oDimension As DrawingDimension In oSheet.DrawingDimensions
    If TypeOf oDimension Is LinearGeneralDimension Or _
       TypeOf oDimension Is AngularGeneralDimension Then
        Call oDimension.CenterText
Next
 I hope this helps, greetings!
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Thanks its working.
blandb
Any idea as to why I have to run this rule twice before it will center them?
Autodesk Certified Professional
