Inventor crashes while closing down when userform addin is active
basnederveen
basnederveen
Title sais all basically, if I close down inventor with my addins' userfrom active, I get a crash while inventor is closing.
How do I prevent this?
Thanks in advance
marcin_otręba
add some code to unload form in addin deactivate sub...
bradeneuropeArthur
Form.show cd form.showdialog this will do ....
Arthur Knoors
Autodesk Affiliations:
bradeneuropeArthur
Vs
Arthur Knoors
basnederveen
I've just added
form.Close() to the deactivate sub, this works. Kind of obvious. Thanks though!
