- Mute
- Permalink
- Report
Hi folks,
Here in the folowing example, I'm using the command manager to pick a surface (pipe) to add a component.
I'm creating the component, adding to assembly, placing the constraints around the pipe, etc.
The last constraint that I didn't add is in the axis of the pipe. The component can move left & right according to the axis. As for now it is landing randomly along the axis. Whould there be somehow a way to get the 3D point where I clicked using the commandManager.Pick method ?
Thank you & kind regards,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"Solved! Go to Solution.
