I am needing to write an i-logic rule that will change the center sketch of an existing surface loft feature.
I am able to create a new loft without any issues using vba in the i-logic vba. However, when I attempt to edit centerline of the loft to use the new sketch profile, I get the following error:
Member not found. (Exception from HRESULT: 0x80020003 (DISP_E_MEMBERNOTFOUND))
Also, I have had no luck in trying to modify the section profiles of a loft either.
The reason I cannot create a new loft instead of modify is because there are several children features that were built using the gui which use this loft.
thanks.
