Inventor API Pattern Elements from Rectangular Pattern
florian_wenzel
florian_wenzel
Inventor 2022
API VB.NET VisualStudio
i try to use the Pattern Elements from my Rectangular Pattern, but without succes.
In Part Enviroment, i want to Pattern a WorkPlane 5 Times, fit to Path Lenght.
This Works.
Then i want to have Acces to the 2 or 3 WorkPlane from Pattern Elements, how to do this?
This is my Code:
Imports System.Runtime.InteropServices
Imports Inventor
Imports Microsoft.Win32
Imports System.Collections.Generic
Imports System.Linq
Module CommandFunctionButton_12
    Public Sub CommandFunctionfweButton_12()
        Dim oPartDoc As PartDocument = g_inventorApplication.ActiveDocument
        Dim oCompDef As PartComponentDefinition = oPartDoc.ComponentDefinition
        Dim oTO As TransientObjects = g_inventorApplication.TransientObjects
        Dim oTG As TransientGeometry = g_inventorApplication.TransientGeometry
        'Pick the Line
        Dim oLine As SketchLine = CType(g_inventorApplication.CommandManager.Pick(SelectionFilterEnum.kSketchCurveLinearFilter, "Pick a Line"), SketchLine)
        'Create Start point
        Dim oPoint As SketchPoint
        oPoint = oLine.StartSketchPoint
        'Create WorkPlane
        Dim oWorkplane As WorkPlane
        oWorkplane = oCompDef.WorkPlanes.AddByNormalToCurve(oLine, oPoint)
        'Create Object Coll for WorkPlane
        Dim oObjColl_01 As ObjectCollection
        oObjColl_01 = oTO.CreateObjectCollection
        oObjColl_01.Add(oWorkplane)
        'Create Path
        Dim oPath As Path = oCompDef.Features.CreatePath(oLine)
        Dim Count As Object = 5
        'Create Pattern Def
        Dim oRectPatternDef As RectangularPatternFeatureDefinition
        oRectPatternDef = oCompDef.Features.RectangularPatternFeatures.CreateDefinition(oObjColl_01, oPath, True, Count, PatternSpacingTypeEnum.kFitToPathLength)
        oRectPatternDef.XDirectionSpacingType = PatternSpacingTypeEnum.kFitToPathLength
        oRectPatternDef.OrientationMethod = PatternOrientationEnum.kAdjustToDirection1
        'Create Pattern Feature
        Dim oRectPattern As RectangularPatternFeature
        oRectPattern = oCompDef.Features.RectangularPatternFeatures.AddByDefinition(oRectPatternDef)
        'till this Moment Works Fine
        Dim oObjColl_Pattern As ObjectCollection
        oObjColl_Pattern = oTO.CreateObjectCollection
        oObjColl_Pattern.Add(oRectPattern.PatternElements)
        ''For Each oWorkPlaneColl As WorkPlane In oRectPattern.PatternElements()
        ''    oObjColl_Pattern.Add(oWorkPlaneColl)
        ''Next
        Dim oWorkPlane_02 As WorkPlane
        oWorkPlane_02 = oObjColl_Pattern(2)
        Dim oWorkPlane_03 As WorkPlane
        oWorkPlane_03 = oObjColl_Pattern(3)
        Dim oSketch_01 As PlanarSketch
        oSketch_01 = oCompDef.Sketches.Add(oWorkplane)
        Dim oSketch_02 As PlanarSketch
        oSketch_02 = oCompDef.Sketches.Add(oWorkPlane_02)
        Dim oSketch_03 As PlanarSketch
        oSketch_03 = oCompDef.Sketches.Add(oWorkPlane_03)
        Dim oCenterPoint_01 As SketchPoint
        oCenterPoint_01 = oSketch_01.SketchPoints.Add(oTG.CreatePoint2d(0, 0))
        Dim oCenterPoint_02 As SketchPoint
        oCenterPoint_02 = oSketch_02.SketchPoints.Add(oTG.CreatePoint2d(0, 0))
        Dim oCenterPoint_03 As SketchPoint
        oCenterPoint_03 = oSketch_03.SketchPoints.Add(oTG.CreatePoint2d(0, 0))
        Dim oCircle_01 As SketchCircle
        oCircle_01 = oSketch_01.SketchCircles.AddByCenterRadius(oCenterPoint_01, 1)
        Dim oCircle_02 As SketchCircle
        oCircle_02 = oSketch_02.SketchCircles.AddByCenterRadius(oCenterPoint_02, 2)
        Dim oCircle_03 As SketchCircle
        oCircle_03 = oSketch_03.SketchCircles.AddByCenterRadius(oCenterPoint_03, 3)
    End Sub
End Module
Thanks for any Sugesstion
Michael.Navara
You need to access to  oRectPattern.PatternElements(i).ResultFeatures(1). This is the work plane except the first element. There you need to use the source oWorkPlane instead.
Sub Main()
    'Pick the Line
    'Create Start point
    'Create WorkPlane
    'Create Path
    'Create Pattern Def
    Dim centerPoint = ThisApplication.TransientGeometry.CreatePoint2d(0, 0)
    CreateSketchWithCircle(oWorkplane, centerPoint, 1)
    For i = 2 To oRectPattern.PatternElements.Count
        Dim element As FeaturePatternElement = oRectPattern.PatternElements(i)
        Dim elementWorkPlane As WorkPlane = element.ResultFeatures(1)
        Dim radius As Double = i
        CreateSketchWithCircle(elementWorkPlane, centerPoint, radius)
    Next
End Sub
Sub CreateSketchWithCircle(workPlane As WorkPlane, centerPoint As Point2d, radius As Double)
    Dim oCompDef As PartComponentDefinition = workPlane.Parent
    Dim elementSketch = oCompDef.Sketches.Add(workPlane)
    elementSketch.SketchCircles.AddByCenterRadius(centerPoint, radius)
End Sub
florian_wenzel
Thanks for Help, thanks for Solution
