Inventor Api: find Connection between Sketch Dimension(DimensionConstraint) and Model Dimension(LinearModelDimension)
Holzethekid
Holzethekid
Hallo,
since Inventor 22 it is possible to promote SketchDimensions via code. See here
Holzethekid_2-1635603755987.pngvia UI
The Model Dimensions promoted via 'Inventor' has the great feature that if i change an value in the sketch the value in the Model Value will change to.
Manuell created Model Dimensions do not have this feature.
I Assume that the Sketch Dimension (DimensionConstaint) and the Model Dimension (ModelDimension) are somehow connected.
I was checking the documentation, but i did not find any connection between the two objects.
Can somebody help me to find the connection between these objects, or how can i find out if one DimensionConstraint is already promoted and get the object ?!
Thanks in Advance
Christian
theo.bot
Within the Modeldimensiondefinition you can find the promoted parameter. But for some reason i can't get the parameter. It results in a "not implemented" message. Maybe someone else knows how to deal with this.
Dim oDoc As PartDocument
oDoc = ThisApplication.ActiveDocument
Dim oDef As PartComponentDefinition
oDef = oDoc.ComponentDefinition
Dim oModelDim As ModelDimension
For Each oModelDim In oDef.ModelAnnotations.ModelDimensions
Dim oModelDef As ModelDimensionDefinition
Dim oPara As Inventor.Parameter
oModelDef = oModelDim.Definition
oPara = oModelDef.PromoteParameter
Logger.Info(oPara.Name)
Next
Holzethekid
Hall Theo,
thanks for the anwer. But as you mentioned the 'PromoteParameter' does not work.
I 'found' a  really sketchy solution how to identify a annotation depending on a DimensionConstraint.
I guess that this solution will be very easy to break, and if the other objects
- RadiusModelDimensions
- DiameterModelDimensions
- AngularModelDimensions
will work the same way ?? I don't know
  public ModelAnnotation GetConnectedAnnotation(DimensionConstraint constraint)
            logger.Debug($"GetConnectedAnnotation");
            var annotations = applicationService.GetDocumentAnnotations();
            foreach (var md in annotations.ModelDimensions)
                if (md is LinearModelDimension modelDimension)
                    if (modelDimension.Definition is LinearModelDimensionDefinition lmdd)
                        if (lmdd.IntentOne.Geometry is SketchPoint sp)
                            foreach (var point in constraint.AnchorPoints)
                                if (point is Point2d point2d)
                                    if (sp.Geometry.IsEqualTo(point2d))
                                        if (Math.Abs(constraint._DisplayValue - modelDimension.ModelValue) <= 0)
                                            logger.Debug($"found constraint : {constraint.Parameter.Name} Value:'{constraint.Parameter.Expression}' | modelDimesnion{modelDimension.Name} Value :'{modelDimension.ModelValue}'");
                                            return md as ModelAnnotation;
            return null;
theo.bot
With Inventor 2022.2 update it's now possible to use "Promoteparameter". tested it and it works fine :slightly_smiling_face:
