Inventor 8 VBA in parameters
Hi
This small macro worked fine in Inventor 7, but dont work in R8 ?
Public Function Top(TopType As Double, XTilKnæk As Double, Ben As Double,
TopA As Double, TopB As Double) As Double
If TopType = 2 And XTilKnæk > Ben Then
Top = TopB
Else
Top = TopA
End If
End Function
The function is put into a parameter with
'VBA:Top(TopTypeV;XTilKnæk;Ben1V;Top1aV;Top1bV)'
Looks almost at the connection til VBA has been broken but that can't be can
it' ?
Regards
Lars
I have a lot of these type of parts. I'll check them Monday. I never got
around to checking them in R8 yet anyway...
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"Lars" wrote in message
news:FE17B8E4ACB08E0C542609D16CD87428@in.WebX.maYIadrTaRb...
> Hi
> Top = TopB
> Else
> Top = TopA
> End If
> End Function
can
> it' ?
> Regards
> Lars
My VBA driven parts are working OK...Did these work in R7?
Sean Dotson, PE
"Sean Dotson" wrote in message
news:A93B689929F8C977B61116EB9F7EC18C@in.WebX.maYIadrTaRb...
> Sean Dotson, PE
> > Hi
Double,
> > Top = TopB
> > Else
> > Top = TopA
> > End If
> > End Function
> can
> > it' ?
> > Regards
> > Lars
Is the function defined in the "Functions" module of the document that calls
it?
> Hi
> Top = TopB
> Else
> Top = TopA
> End If
> End Function
can
> it' ?
> Regards
> Lars
Sometimes things just behaves strange, it's working now ??
Regards
Lars
"Brian R. Iwaskewycz" wrote in message
news:333908DCA090C640031AB1D7213BE6E4@in.WebX.maYIadrTaRb...
calls
> it?
> > Hi
Double,
> > Top = TopB
> > Else
> > Top = TopA
> > End If
> > End Function
> can
> > it' ?
> > Regards
> > Lars
