Inventor 2022/2023 slow renaming of browser nodes by code
3 REPLIES 3
daniel.puchta
249 Views, 3 Replies
I have VBA code that renames all browser nodes of top level assembly and its subassemblies. To rename browser node, I have to unsuppress the component, rename it and suppress it again. But for some reason, it is painfully slow - it takes almost 2 hours to complete. I have assembly with 373 referenced files, the assembly has all sorts of subcomponents (subassemblies, parts, content center parts, patterns...) and the code becomes slow when it tries to rename browser nodes of subassembly, which is medium sized and has other subassemblies.
Similar rule did run fast in older versions of Inventor where there has been level of detail and I did it from the main level of detail. But for Inv 2022 and 2023 it is very very slow. Do you have any tips how to make the code run faster?
Public RenamedFiles As Object
    Sub Main()
        Dim oDoc As Inventor.AssemblyDocument
        Set oDoc = ThisApplication.ActiveDocument
        Set RenamedFiles = CreateObject("System.Collections.ArrayList")
        Dim oOccurrence As ComponentOccurrence
        Dim oAsmCompDef As Inventor.AssemblyComponentDefinition
        Dim ListOfOccurrences As Object
        Set ListOfOccurrences = CreateObject("System.Collections.ArrayList")
        Set oAsmCompDef = oDoc.ComponentDefinition
        Dim Item As Variant
        RenameBrowserTree oAsmCompDef.Occurrences
        MsgBox "Renaming finished in time: " & Time
    End Sub
    Sub RenameBrowserTree(Local_Occurrences As ComponentOccurrences)
        Dim oLocal_Component_List As Object
        Set oLocal_Component_List = CreateObject("System.Collections.ArrayList")
        Dim Counter As Integer
        Counter = 0
        Dim TotalCounter As Integer
        TotalCounter = 0
        Dim Limit As Integer
        Limit = 2000
        Dim Local_CurrentIndex As Integer
        Dim iVlastnost_nazev As String
        Dim oKonec_nazvu As String
        Dim oLocal_Occurrence As ComponentOccurrence
        For Each oLocal_Occurrence In Local_Occurrences
            oLocal_Component_List.Add oLocal_Occurrence.Name
        Next
        Dim Indexzadvojteckou As Integer
        Dim OccurrenceIndex As Integer
        Dim OccurrenceRenamed As Boolean
        OccurrenceIndex = 0
        Dim Local_Suppress As Boolean
        Dim oSubDoc As Inventor.AssemblyDocument
            Local_Suppress = False
            If oLocal_Occurrence.Suppressed = True Then
                Local_Suppress = True
                oLocal_Occurrence.Unsuppress
            End If
            If InStr(oLocal_Occurrence.Definition.Document.fullFilename, "\SOC\") = 0 Then 'If occurrence is content center part
                    iVlastnost_nazev = oLocal_Occurrence.Name
                    oLocal_Occurrence.Name = "RandomName"
                    oLocal_Occurrence.Name = iVlastnost_nazev
                    oLocal_Component_List(OccurrenceIndex) = oLocal_Occurrence.Name
                    Counter = Counter + 1
                    OccurrenceIndex = OccurrenceIndex + 1
                    If Local_Suppress = True Then
                        If oLocal_Occurrence.DefinitionDocumentType = kAssemblyDocumentObject Then
                            OccurrenceRenamed = IsOccurrenceRenamed(oLocal_Occurrence.Definition.Document.fullFilename)
                            If OccurrenceRenamed = False Then
                                RenamedFiles.Add oLocal_Occurrence.Definition.Document.fullFilename
                                ThisApplication.SilentOperation = True
                                Set oSubDoc = ThisApplication.Documents.Open(oLocal_Occurrence.Definition.Document.fullFilename)
                                ThisApplication.SilentOperation = False
                                RenameBrowserTree oSubDoc.ComponentDefinition.Occurrences
                                oSubDoc.Save2
                                oSubDoc.Close
                            End If
                        End If
                    Else
                                oSubDoc.Save2
                                oSubDoc.Close
                            End If
                        End If
                    End If
                    If Counter > Limit Then
                        TotalCounter = TotalCounter + Counter
                        'ThisApplication.ActiveDocument.PropertySets.Item("Inventor User Defined Properties").Item("Counter").Value = CStr(TotalCounter)
                        ThisApplication.ActiveDocument.Save2
                        Counter = 0
                    End If
                Else 'Here, Occurrence is content center path
                 End If
                End If
            Next
            If IsObject(oDoc) Then
            Else
            End If
    End Sub
    Function IsOccurrenceRenamed(FileName As String) As Boolean
        Dim Local_FileName As Variant
        For Each Local_FileName In RenamedFiles
            If Local_FileName = FileName Then
                IsOccurrenceRenamed = True
                Exit Function
            End If
        Next
        IsOccurrenceRenamed = False
    End Function
3 REPLIES 3
CCarreiras
in reply to: daniel.puchta
I also find Inventor 2023 slow in many things.
I believe the changes from LOD to Model States caused some changes in the way Inventor manages many things (suppress, properties, etc etc).
I believe that this will be "fixed" over time.... but ....that's only my opinion as a user.
Here...we are only users, we can give some help, and give an opinion, but we can«t do much about how the software works.
Contact product support and describe your issue, they need to know these things to take over and enhance the software.
CCarreiras
daniel.puchta
in reply to: CCarreiras
Hello ccarreiras,
thank you for your reply. On official Autodesk website, it says: "Get answers fast from Autodesk support staff and product experts in the forums." with the link to this forum. So sooner or later this post will be seen by Autodesk support. Also, there are more older posts how to improve performance of VBA code or iLogic Rule, but only not for my issue.
But can you specify How can I contact Autodesk support? I browsed some support links and it looks like it is not intended to solve problems with performance of Inventor API, it is rather intended to more "common" problems like problems with printers..
CCarreiras
It's not easy to find it.... 😅
https://knowledge.autodesk.com/support/inventor
CCarreiras
