Inventor 2017 - load signed DLL
SašoPrijatelj
SašoPrijatelj
we are migrating some of our Inventor addins to 2017. All of them are properly signed (by Comodo Code signing cert) but Inventor still blocks them on loading so the user has to manually unblock them via addin manager.
What are the requirements to make Inventor load signed addins without blocking them?
Sašo.
AutoDXF - automatic flat pattern creation and batch export to DXF for Inventor
Please use "Accept as Solution" & give "Kudos" if this response helped you.
GeorgK
SašoPrijatelj
I read that post on ADN blog. Actually that's how we are doing it at the moment - installer pushes our certificate to cert store to list of trusted certificates during installation. It can be done for current windows user. I just thought that there might be a more elegant solution. Is this actually correct approach?
