Announcements
Inventor 2016 enumerating outer edges
klemen_zivkovic
klemen_zivkovic
Hello guys,
I want to get only outer edges of pipe on picture. I am using attached VBA code to do that.
Does somebody know how can I diferentiate if edge is member of outer surface of pipe and not inner surface of pipe.
I will be thankfull for any idea.
I am running Inventor 2016.
regards,
Replies (21)
adam.nagy
Autodesk Support
Autodesk Support
I assume you might have solved it on your own by now, but I guess that you could check inside the GetOuterEdgesOfFaces function that if you are dealing with a single face and it's cylindrical (oFace.SurfaceType = kCylinderSurface) then you just pass back all the edges.
Adam Nagy
Autodesk Platform Services
klemen_zivkovic
Yes I solved it - your solution works great! Thank you again for your generous support!
