Announcements
Insert snaped to line sketch symbol
hieut1392
hieut1392
I am writing a macro that inserts the sketch symbol, but after inserting the symbol does not stick to the line, it can be dragged anywhere. I want it to stick to the line. Can you help me?
Sub TEST()
Dim oDoc As DrawingDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oSheet As sheet
Set oSheet = oDoc.ActiveSheet
Dim xPos As Double
Dim yPos As Double
Dim oLine As Object
Set oLine = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllEntitiesFilter, "Pick a line")
xPos = oLine.StartPoint.x
yPos = oLine.StartPoint.y
Dim oSketchedSymbolDef As SketchedSymbolDefinition
Set oSketchedSymbolDef = oDoc.SketchedSymbolDefinitions.Item("MySymbol")
Dim oTG As TransientGeometry
Set oTG = ThisApplication.TransientGeometry
Dim oSketchedSymbol As SketchedSymbol
Set oSketchedSymbol = oSheet.SketchedSymbols.Add _
                        (oSketchedSymbolDef, oTG.CreatePoint2d(xPos, yPos), 0, 1)
End Sub
JelteDeJong
You should have a look at the method "SketchedSymbols.AddWithLeader". (In the help files there is also an example.)
Suppose you created the sketch symbol (with a leader). Then you can hide (not delete) the leader with the property LeaderVisible.
SketchedSymbol.LeaderVisible = False
Jelte de Jong
Blog: hjalte.nl - github.com
hieut1392
thanks for your helping. my code is below.
Sub XXX(name As String, rotary As String)
' Set a reference to the drawing document.
' This assumes a drawing document is active.
Dim oDrawDoc As DrawingDocument
Set oDrawDoc = ThisApplication.ActiveDocument
' Set a reference to the active sheet.
Dim oActiveSheet As sheet
Set oActiveSheet = oDrawDoc.ActiveSheet
Repeat:
Dim oLine As Object
If (Not oLine Is Nothing) Then
    ' Set a reference to the drawing curve segment.
    ' This assumes that a drwaing curve is selected.
    Dim oDrawingCurveSegment As DrawingCurveSegment
    Set oDrawingCurveSegment = oLine
    ' Set a reference to the drawing curve.
    Dim oDrawingCurve As DrawingCurve
    Set oDrawingCurve = oDrawingCurveSegment.Parent
    ' Get the mid point of the selected curve
    ' assuming that the selection curve is linear
    Dim oMidPoint As Point2d
    Set oMidPoint = oDrawingCurve.MidPoint
    ' Set a reference to the TransientGeometry object.
    Dim oLeaderPoints As ObjectCollection
    Set oLeaderPoints = ThisApplication.TransientObjects.CreateObjectCollection
    ' Create a few leader points.
    Call oLeaderPoints.Add(oTG.CreatePoint2d(oMidPoint.x, oMidPoint.y))
    ' Create an intent and add to the leader points collection.
    ' This is the geometry that the symbol will attach to.
    Dim oGeometryIntent As GeometryIntent
    Set oGeometryIntent = oActiveSheet.CreateGeometryIntent(oDrawingCurve)
    Call oLeaderPoints.Add(oGeometryIntent)
    ' Get the first symbol definition
    Dim oSketchSymDef As SketchedSymbolDefinition
    Set oSketchSymDef = oDrawDoc.SketchedSymbolDefinitions.Item(name)
    ' Create the symbol with a leader
    Set oSketchedSymbol = oActiveSheet.SketchedSymbols.AddWithLeader(oSketchSymDef, oLeaderPoints, rotary, , , False)
    GoTo Repeat
End Sub
