Insert sketch symbol using ilogic rule
I would like to insert sketch symbol with the name "TAG" into the active drawing using a rule. User will then pick location. This sketch symbol has no prompted entries.
In the other case i would like to insert a sketch symbol with name "REF" into the active drawing but this sketch symbol will have prompted entries. Also with user to pick location.
Replies (15)
Sergio.D.SuƔrez
Hi, Here I share a drawing file in Inventor 2018, in which I have two sketch symbols. The first sketch symbol has four requested entries, the second sketch symbol has no requested entries. There are four ilogic rules, two for each sketch symbol.
One of the rules will place the sketch symbol in a position determined by coordinates.
The second rule will place the sketch symbol with the mouse.
Note that the sketch symbol with 4 entries has the sproptstring defined in (3) that is because it counts from zero.
I hope this helps. regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Thank you for this, this could work. Is there a way to have the sketch symbol preview so the user has an idea of where it will be placed? The preview would work the same as inserting a sketch symbol through double clicking thorugh the  the tree.
Adding to the above, ideally it would be great have the ability to snap to existing geometry using the insertion insertion point grip.
Thanks again.
Hello, I was also wondering if it is possible to control/toggle the symbol library options within the code.
Main goal is I have some sketch symbols that would require a leader and others that don't.
Symbol library options:
Symbol Clipping
Static
Leader
Visible options
Andrew_Burnett
Has anyone found a way to get the inserting symbol snap to a grip on an existing symbol?  I am wanting to use this for some notes that we place on the drawing and stack them on top of the title block.
Thank you in advance.
jigneshah25
Thanks for the Sample Code. Can we control the sketch selection via excel linked parameter. For example if I want to replace certain sketch based on selection made in Excel sheet linked with Inventor Model.
Hi everyone, is it technically possible to create a rule that would insert symbols from a library that is located on a server?
Hi - The only way to add a sketch symbol that is not located in the actual drawing is by using the sketch symbol library. Is it possible to add from the server, yes but that would mean you need to path to the sketch symbol library to that location in the server. Would this server location be static or would it vary based on drawing? If I understand a bit more your parameters and end goal I believe I can assist.
Curtis_Waguespack
Hi @Anonymous ,
If your Tools > application options > Files > Symbol Library path is specifying the server path, then you could use something like this.
I hope this helps.
Curtis
'this is the name of the symbol library file,
'the path to this location is specified under
'Tools tab > Application Options button > Files tab
oSymbolDrawingName = "Sketched Symbols"
'This is the name of the symbol to place
oSymbolName = "Test101"
'check file type
If ThisDoc.Document.DocumentType <> kDrawingDocumentObject Then
Return
End If
'define the drawing document
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
Dim oSketchSymLib As SketchedSymbolDefinitionLibrary
oSketchSymLib = oDrawDoc.SketchedSymbolDefinitions.SketchedSymbolDefinitionLibraries.Item(oSymbolDrawingName)
Dim oSymDef As SketchedSymbolDefinition
'place the symbol in the Drawing Resources folder
oSymDef = oDrawDoc.SketchedSymbolDefinitions.AddFromLibrary(oSketchSymLib, oSymbolName, True)
Dim oPosition As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(10, 15)
'[use this if the symbol has no prompted entry
Dim oSymbol As SketchedSymbol
oSymbol = oDrawDoc.ActiveSheet.SketchedSymbols.Add(oSymDef, oPosition, 0, 1, )
''or
''[ use this if the symbol has prompted entry
'Dim sPromptStrings(2) As String 'string array with 2 items, for two prompts
'sPromptStrings(0) = "Hello"
'sPromptStrings(1) = "World"
'Dim oSymbol As SketchedSymbol
'oSymbol = oDrawDoc.ActiveSheet.SketchedSymbols.Add(oSymDef, oPosition, 0, 1, sPromptStrings)
Hi, thank you. It works great. And I have one more question. Our library contains more items. It is possible for a dialogue to appear at the beginning and to be able to choose what I need.
Curtis_Waguespack
Hi @Anonymous
Give this a try.
I hope this helps.
Curtis
'check file type
Return
End If
Dim oSymbolList As New ArrayList
For Each oSymbolDef In oSketchSymLib.SketchedSymbolDefinitions
	oSymbolList.Add(oSymbolDef.name)
Next
oName = InputListBox("Pick a Symbol",oSymbolList, oSymbolList(0), "iLogic", "List of Symbols")
If oName = "" Then
	Return 'exit rule
End If
oSymDef = oDrawDoc.SketchedSymbolDefinitions.AddFromLibrary(oSketchSymLib, oName, True)
That's great. Thanks. You helped me a lot.
creggo
Works great, just wondering if there's a way to force on the static option?
A.Acheson
Here is the syntax for below from API help
oSymbol.Static = True
If this solved a problem, please click (accept) as solution.ā€Œā€Œā€Œā€Œ
Or if this helped you, please, click (like)ā€Œā€Œ
Regards
Alan
ArunJNXXNQ
Hi, i am looking for the exact case, where a preview would be ideal. Do you have a code that works for this?
