Insert DXF or DWG into a planar sketch using COM/C++
- Mute
- Permalink
- Report
In the API help there is some VB code to do this and I'm translating it into COM/C++.
I think I'm there but I've probably used a bad cast or a wrong pointer type because the very last part crashes
// THIS CALL CRASHES, I SUSPECT THE LAST PARAMETER hRes = pDwgTranslator->Open(pDataMedium, pTranslationContext, pOptions, (IDispatch**)&pPartDoc);
I also suspect this line of mine:
pTranslationContext->OpenIntoExisting = pNewSketch ;
I'm also not sure about...
CComPtr<ApplicationAddIn> pAppAddIn;
hRes = pAppAddIns->get_ItemById(CComBSTR("{C24E3AC2-122E-11D5-8E91-0010B541CD80}"), &pAppAddIn);
if (FAILED(hRes)) {
gLogger.Printf(ekErrMsg, L"get_ItemById failed");
return;
CComPtr<TranslatorAddIn> pDwgTranslator;
pDwgTranslator = pAppAddIn; // Is this correct?
The full fragment is here...
hRes = pInvApp->get_ApplicationAddIns(&pAppAddIns);
if (FAILED(hRes)) {
gLogger.Printf(ekErrMsg, L"get_ApplicationAddIns failed");
return;
if (FAILED(hRes)) {
return;
if (pDwgTranslator == nullptr) {
gLogger.Printf(ekErrMsg, L"pDwgTranslator = pAppAddIn did not work");
return;
CComPtr<TransientObjects> pTransientObjects = GetTransientObjectsPtr();
CComPtr<DataMedium> pDataMedium;
hRes = pTransientObjects->CreateDataMedium(&pDataMedium);
if (FAILED(hRes)) {
gLogger.Printf(ekErrMsg, L"CreateDataMedium failed");
return;
pDataMedium->put_FileName(CComBSTR("C:\\Users\\Owen\\TEST.dxf"));
CComPtr<TranslationContext> pTranslationContext;
hRes = pTransientObjects->CreateTranslationContext(&pTranslationContext);
if (FAILED(hRes)) {
gLogger.Printf(ekErrMsg, L"CreateTranslationContext failed");
return;
hRes = pNewSketch->Edit();
if (FAILED(hRes)) {
gLogger.Printf(ekErrMsg, L"Edit failed");
return;
// !!! I SUSPECT THIS !!!
CComPtr<NameValueMap> pOptions;
hRes = pTransientObjects->CreateNameValueMap(&pOptions);
if (FAILED(hRes)) {
return;
// Specify the layers to import
pOptions->Add(BSTR("SelectedLayers"), CComVariant("0"));
pOptions->Add(BSTR("InvertLayersSelection"), CComVariant (VARIANT_TRUE));
// Specify the units
pOptions->Add(BSTR("FileUnits"), CComVariant("Centimeters"));
// ' Set to constraint the end points.
pOptions->Add(BSTR("ConstrainEndPoints"), CComVariant (VARIANT_TRUE));
// !!!THIS CALL CRASHES I SUSPECT THE LAST PARAMETER!!!
if (FAILED(hRes)) {
gLogger.Printf(ekErrMsg, L"Open DataMedium failed");
return;
pNewSketch->ExitEdit();
