Attention for Customers without MFA or SSO - OTP Verification rolls out April 2025. Read all about it here.
Initialising a vba macro in every new part
fisaVMY4M
fisaVMY4M
Hallo,
Is there a way to install a vba macro in inventor so that every new part or assembly has it?
Thanks for the answers.
Greetings
l_dalise
If I understand you correctly, you want to create a macro that every new file must contain, right?
You can insert the macro in the .ipt or .iam template model, so every new part created has the macro
And if you need it to be initialized when you open the document or when you create a new file, you can put that macro (or rule) in the Event Trigger
fisaVMY4M
Yeah eather way would be fine. I created a macro already but failed to put it in the template. Do you know in which folder i need to put it?
And if you could provide me with infos about the integration with an event trigger i would be happy too.
Thanks alot and have a good weekend.
fisaVMY4M
Got it. I just put it in the application project.
bradeneuropeArthur
Maybe this is of the topic, but by experience I would advice to create a add-in for these circumstances/cases.
Arthur Knoors
Autodesk Affiliations:
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
