Inconsistent Relationship that disappears when dragged in iLogic driven assembly
andrew.tom.reynolds
andrew.tom.reynolds
I have an assembly that is configured using an excel spreadsheet and ilogic rules.
Once everything is updated and saved, there is a pattern that is still sitting out of place and the design doctor is highlighting an issue with an "inconsistent constraint" which is a mate between a work plane and an axis of a hole in one of the patterned components.
Thing is, as soon as you grab the pattern and drag with the mouse, it "snaps" correctly into place and the issue disappears (design doctor greys out).
Prior to dragging, there is no updates pending and rebuild all does nothing to resolve either.
I've tried deleting and re-creating the constraint and get the same result. I've also tried creating a work axis and using that to mate with the work plane instead of just the hole and also get the same result. Unfortunately I have to use an axis to the plane so that the object can pivot in a positional representation based on another constraint.
Any suggestions in how to force the update without having to manually grab and drag each time??
Replies (0)
