Import Customization (Customize) settings with iLogic
ReneRepina
ReneRepina
is there any way to import Customization (Customize) settings with iLogic?
Best regards,
Rene Repina
bradeneuropeArthur
What I can remember is that it is not supported via the API. You could try to load them on startup.
With this:
https://forums.autodesk.com/t5/inventor-forum/start-inventor-with-fix-application-options/td-p/27565...
Arthur Knoors
Autodesk Affiliations:
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
bradeneuropeArthur
Arthur Knoors
JelteDeJong
You might have a look at this page. The command line arguments /IMPORTCUSTOMIZATIONS and /IMPORTRIBBONCUSTOMIZATONS do not work unless you use them with the argument /INSTALL. But its is what i use to setup computers of new users.
Jelte de Jong
Blog: hjalte.nl - github.com
bradeneuropeArthur
That is a good addition @JelteDeJong !
Arthur Knoors
ReneRepina
@bradeneuropeArthur
@JelteDeJong
Thank you for the answers! I already saw that thread import at startup, but I would need via iLogic. The thing is, some users already have customized menus and I do not wanna mess their menus. I would like to create an iLogic, when it would run at certain times (or manual), asking users if they want to import "Company Default menu".
I am afraid that like @bradeneuropeArthur said, it is not supported in API. Unless somebody got some other information about it?
