IMOS
IMOS
IMOS
Hi. I am using IMOS 12.0 for months now.
i have a cabinet in which its door hinge power factor will depend on the (a)door weight and (b)width. rather than making every width of the cabinet and every door type, is there a way to shortcut the process? it will just take so much time to edit every single one if a problem arise.
applying it in $Variables will still have user intervention. and if the user doesn't have the knowledge about the need to change the hinge, then it might cause more problems.
that's why i thought of the possibility to have an "If...else.." command in the Element Manager but i don't know how to state the command and if it is possible. is there a way in which imos will recognize the "IF..ELSE.." statement and the cabinet size and weight, so that it will automatically set the proper power factor the hinge mechanism of the door need?
thanks in advance
Jef_E
What is IMOS and how is it related to Autodesk Inventor Customization?
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
