Immediate parameter update in iLogic rule
I've searched and incorporated proposed solutions to this, but not finding it working.  Hashed rule posted below.  Below just a step in developing a more comprehensive approach (form input etc).
I want to input a value for a parameter and then be given the value of a dependent function based parameter, then be prompted to adjust the first parameter if required.  However the dependent parameter returned is the old value; it isn't updating immediately.  Relevant Sub is Format_L.  Anyone who can help?  Thanks!
Sub main
	'check that this active document is a part file
	Dim partDoc As PartDocument
	'call subs
	SetProjectProperties
	Format_L
	AppendSBPrefix
	InventorVb.DocumentUpdate()
End Sub
Sub Format_L
	'Set the relevant left side run length and squab parameters
	Parameter("Length_A") = InputBox("Please enter overall booth run length 'A' in mm", "Layout length 'A'", Length_A)
	Parameter("Squab_No_A") = InputBox("Please enter number of squabs reguired for run length 'A'", "No. squabs run 'A'", Squab_No_A)
	'Set the relevant right side run length and squab parameters
	Parameter("Length_B") = InputBox("Please enter overall booth run length 'B' in mm", "Layout length 'B'", Length_B)
	Parameter("Squab_No_B") = InputBox("Please enter number of squabs reguired for run length 'B'", "No. squabs run 'B'", Squab_No_B)
	'Update the parameters immediately
	RuleParametersOutput()
	'Set the relevant carcass parameters
	Parameter("Carcass_Length_Limit") = InputBox("Please enter maximum carcass length for shipping/handling", "Carcass limit length", Carcass_Length_Limit)
	Parameter("Spine_No_A") = InputBox(Spine_Spacing_IS_A, "Please adjust run 'A' spine quantity if required", Spine_No_A)
	Parameter("Spine_No_B") = InputBox(Spine_Spacing_IS_B, "Please adjust run 'B' spine quantity if required", Spine_No_B)
End Sub
Sub SetProjectProperties
	Dim oProject As String
	Dim oProductNo As String
	oProject = InputBox("Enter the Sales Order number", "Sales Order", iProperties.Value("Project", "Project"))
	oProductNo = InputBox("Enter the Product Number for this layout", "Product Number", iProperties.Value("Project", "Part Number"))
	'write input back to custom iProperty
	iProperties.Value("Project", "Project") = oProject
	iProperties.Value("Project", "Part Number") = oProductNo
	oPrefix = oProductNo & "_"
	iProperties.Value("Custom", "Prefix") = oPrefix
End Sub
Sub AppendSBPrefix
	'define the active document
	partDoc = ThisApplication.ActiveDocument
	Dim SB As SurfaceBody
	Dim SBName
	'write the prefix
	oPrefix = iProperties.Value("Custom", "Prefix")
	'rename all solid bodies incrementing counter (counter not presently used, left in event required later)
	Dim i As Integer
	i = 1
	For Each SB In partDoc.ComponentDefinition.SurfaceBodies
	SB.Name = oPrefix + SB.Name
	i = i + 1
	Next
End Sub
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Can you please provide sample model data to test the behavior? please make sure that files are non confidential.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
clutsa
You want the immediate value of "Spine_Spacing_IS_B"? You need to use the Parameter("Spine_Spacing_IS_B") function to get it...
Sub Format_L
	Parameter("Spine_No_A") = InputBox(Parameter("Spine_Spacing_IS_A"), "Please adjust run 'A' spine quantity if required", Spine_No_A)
	Parameter("Spine_No_B") = InputBox(Parameter("Spine_Spacing_IS_B"), "Please adjust run 'B' spine quantity if required", Spine_No_B)
End Sub
If I've helped you, please help me by supporting this idea.
Mass Override for Each Model State
Custom Glyph Icon for iMates
