iLogic
iLogic
Hi iLogic Users
I have a question about iLogic, I have been using this code for turning on/off solids in a part. this has been working fine until I reinstalled FDS.
maybe  you can help.
Is there something wrong with this code??
SyntaxEditor Code Snippet
Dim oCompDef as ComponentDefinition=ThisDoc.Document.ComponentDefinition
For Each oBody As SurfaceBody In oCompDef.SurfaceBodies
 Another thing.
Has any of you found a way to turn of a feature occurence in a pattern in a part ?
Br. Pia
SašoPrijatelj
The code you posted does nothing. It's only the beginning of the code. Did you make a mistake when copy-pasting or is that actual code you try to use?
AutoDXF - automatic flat pattern creation and batch export to DXF for Inventor
Please use "Accept as Solution" & give "Kudos" if this response helped you.
Hi
Yes it´s the beginning of the code after that it could be like this.
If TheCodeAreRight then
If oBody.Name="Solid1"then oBody.Visible=1
Else
 If oBody.Name="Solid1"then oBody.Visible=0
End if
Next
Hope this make more sense :slightly_smiling_face:
- Pia
SašoPrijatelj
Try this - it will make Solid2 invisible and Solid1 visible:
Dim oCompDef As ComponentDefinition = ThisDoc.Document.ComponentDefinition
	'If TheCodeAreRight Then
	If oBody.Name = "Solid1" Then
		oBody.Visible=1
	Else If oBody.Name = "Solid2" Then
		oBody.Visible=0
	End If
Next
what´s the difference between the code you posted and the one that I posted ?
And why, does it suddenly not work anymore. ?
Br- Pia
SašoPrijatelj
Even is structure of your code was correct (it's missing one EndIf) it would do nothing because in first IF statement you turn off SOLID1 and in second IF you turn on the same SOLID1.
Okey Sounds plausible.
What about this ?
If Code="On"then
if obody.name="Solid1"then oBody.Visible=1
else if Code="Off"then
If oBody.name="Solid1"then Obody.Visible=0
End if
Next
Still confused about, why it worked before reinstalling FDS2016?
-Pia
