iLogic
iLogic
So I've created an ipt file that uses iLogic to automate the design of the part I want to make. With each part, I also need to generate a drawing, so I was wondering if there is some sort of coding in iLogic that I can put in a rule to run whenever I want to generate a drawing from the part I have. The placement of the dimensions and types of views are always the same, so if the drawing could automate those as well that would be awesome.
I've researched this already, but all the solutions I've found utilize imports, and I don't know how to access those libraries. So, if there's a way around that I'd like to know, and if not then how do you utilize imports?
mcgyvr
Could you do a "tabulated drawing" so you only need 1 drawing to apply to ALL parts?
Something like this http://www.cadalyst.com/files/cadalyst/nodes/2008/11176/0208SolidEdge1.jpg
mflayler
If you have an existing part and drawing already created in the same workspace, I have some code that will do that for you.
Essentially it performs a Save Copy As for both the part and the drawing and then uses the Replace Model Reference to switch out the model reference in the drawing to the new file.  This code would not work if the drawing does not already exist.
Is that scenario acceptable?
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
That would work. I was hoping that I could come up with something that would work even if the drawing doesn't already exist, but that's not absolutely crucial. Thanks for you help!
mflayler
Here is the information on the code I have...
http://blogs.rand.com/manufacturing/2016/06/ilogic-inventor-enhanced-save-as.html
Disclaimer...I didn't write it, but i slightly modified it.
