iLogic, Work with parts only in specific folders in Assembly tree
mgasser8SSYT
mgasser8SSYT
Hello Everyone
I like to change the suppression on specific files in a folder within a assembly tree.
I realized it without folder and it works fine. Now I have two Folders with nearly same content and want to unsuppress a specific part in folder "Mast1" and a different part in folder "Mast2" . We get the specific component name from the Parameter Table in the Parameters "Mast1Nr" and "Mast2Nr". How do I realize that?
(The early working code I coded [without folders] is attached)
Frederick_Law
You need FullFileName from Document Object to get Folder name.
https://help.autodesk.com/view/INVNTOR/2023/ENU/?guid=GUID-CF60F6F3-8074-4719-B8E0-5E482E5AF783
