Sure!
This is the most important one.
Sub Main()
'Prevents Inventor from crashing.
InventorVb.DocumentUpdate()
'Check if open document is sheetmetal
Dim oDoc As Document = ThisApplication.ActiveDocument
If oDoc.DocumentSubType.DocumentSubTypeID <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
Exit Sub
Else
End If
'MsgBox("Is sheetmetal")
'Check if open sheetmetal document has flatpattern view
Dim oSMD As SheetMetalComponentDefinition
oSMD = oDoc.ComponentDefinition
If Not oSMD.HasFlatPattern Then Exit Sub
Dim oFlat As FlatPattern = oSMD.FlatPattern
'MsgBox("Has flatpattern")
'Check for bend features
Try
Dim BendCount As Integer = oSMD.Bends.Count
If BendCount < 1 Then Exit Sub
'MsgBox("# bends " & BendCount)
Catch
'MsgBox("error: Sheetmetalcomponentdefinition.Bends.Count (Can't find bends?)")
Exit Sub
End Try
'Check if feature "BendMarkerHoles" exists
Dim FeatureName As String = "BendMarkerHoles"
Try
Dim oFTS As FlatPatternFeatures = oFlat.Features
If oFTS.Count > 0 Then
For Each oFT As PartFeature In oFTS
If oFT.Name <> FeatureName Then Continue For
Try
oFT.Delete()
Catch
End Try
Exit For
Next
End If
Catch
MsgBox("error in MAIN()")
End Try
BendMarker(oFlat)
End Sub
Sub BendMarker(oFlat As FlatPattern)
Dim oEdges As Edges
Dim oHoleCenters As Object = ThisApplication.TransientObjects.CreateObjectCollection
Dim oSketch As PlanarSketch
'Flatpattern sketch -------------------------------------------------------------------------
Try
oSketch = oFlat.Sketches.Add(oFlat.TopFace, True)
Catch
oSketch = oFlat.Sketches.Add(oFlat.BottomFace, True)
End Try
oSketch.Edit()
'Detect bend down ---------------------------------------------------------------------------
Try
oEdges = oFlat.GetEdgesOfType(FlatPatternEdgeTypeEnum.kBendDownFlatPatternEdge, True)
WorkEdges(oHoleCenters, oSketch, oEdges)
Catch
MsgBox("error: GetEdgesOfType 64005/kBendDownFlatPatternEdge")
End Try
'Detect bend up -----------------------------------------------------------------------------
Try
oEdges = oFlat.GetEdgesOfType(FlatPatternEdgeTypeEnum.kBendUpFlatPatternEdge, True)
Catch
MsgBox("error: GetEdgesOfType 64004/kBendUpFlatPatternEdge")
End Try
Call oFlat.Features.HoleFeatures.AddDrilledByThroughAllExtent(oHoleCenters, 0.1, kPositiveExtentDirection)
Try
Dim oHoleFeat As HoleFeature = oFlat.Features.HoleFeatures.Item(1)
oHoleFeat.Name = "BendMarkerHoles"
oSketch.ExitEdit()
oSketch.Name = "MarkedBends"
Catch
MsgBox("error: GetEdgesOfType kBendUpFlatPatternEdge (64004) en/of kBendDownFlatPatternEdge (64005) kunnen niet worden gevonden")
End Try
End Sub
Sub WorkEdges(ByRef oHoleCenters As Object, ByRef oSketch As PlanarSketch, oEdges As Edges)
'Create list of coördinates
Dim oDoc As Document = ThisDoc.Document
Dim oLoft As Integer = 0
For Each HFeature As LoftedFlangeFeature In oSMD.Features.LoftedFlangeFeatures
oLoft = 1
Next
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
Dim Xi As Integer = 0
BendCount *= 4
Dim oPointGrid(BendCount, 1) As Double
For Each oEdge As Edge In oEdges
Try
Dim oEnt As SketchEntity = oSketch.AddByProjectingEntity(oEdge)
oPointGrid(Xi, 0) = oEnt.StartSketchPoint.Geometry.X.ToString
oPointGrid(Xi, 1) = oEnt.StartSketchPoint.Geometry.Y.ToString
Xi = Xi + 1
oPointGrid(Xi, 0) = oEnt.EndSketchPoint.Geometry.X.ToString
oPointGrid(Xi, 1) = oEnt.EndSketchPoint.Geometry.Y.ToString
Xi = Xi + 1
oEnt.Delete 'Deleting projected geometry
Catch
'MsgBox("error")
End Try
Next
If Xi = 0 Then Exit Sub
'Loft Filter Start
If oLoft = 0 Then GoTo Endloft
'MsgBox("Loft Code")
Dim intCount1, intCount2 As Integer
Dim DictX As Object = CreateObject("Scripting.Dictionary")
Dim DictY As Object = CreateObject("Scripting.Dictionary")
'Filter Points within certain promximity of each other
For intCount1 = 0 To Xi
For intCount2 = 0 To Xi
If intCount1 <> intCount2 Then
' 2D-array
' |_0__|_1__|
' 0|_X__|_Y__| 0,0 = x coördinate 0,1 = y coördinate
' 1|_X__|_Y__| 1,0 = x coördinate 1,1 = y coördinate
' 2|_X__|_Y__| 2,0 = x coördinate 2,1 = y coördinate
' X-Value intCount1 X-Value intCount2 Y-Value intCount1 Y-Value intCount2
' Compare 2D Array Cel X,0 With 2D Array Cel X,0 And Compare 2D Array Cel X,1 With 2D Array Cel X,1
If EqualWithinTolerance(oPointGrid(intCount1, 0), oPointGrid(intCount2, 0), 0.1) And EqualWithinTolerance(oPointGrid(intCount1, 1), oPointGrid(intCount2, 1), 0.1) Then
Try
DictX.Add(oPointGrid(intCount2, 0) & " " & oPointGrid(intCount2, 1), oPointGrid(intCount2, 0))
DictY.Add(oPointGrid(intCount2, 0) & " " & oPointGrid(intCount2, 1), oPointGrid(intCount2, 1))
Catch
'Nothing
End Try
End If
End If
Next intCount2
Next intCount1
'MsgBox("IntCount " & intCount1 & " " & intCount2)
'Filter points.
'Only the points which are not close to each other remain.
Dim i As Integer = 0
Dim oPointGridFilteredX As Object = CreateObject("Scripting.Dictionary")
Dim oPointGridFilteredY As Object = CreateObject("Scripting.Dictionary")
For i = 0 To Xi
If Not Xi = 0 Then
If Not DictX.Exists(oPointGrid(i, 0) & " " & oPointGrid(i, 1)) Then
oPointGridFilteredX.Add(oPointGrid(i, 0) & " " & oPointGrid(i, 1), oPointGrid(i, 0))
oPointGridFilteredY.Add(oPointGrid(i, 0) & " " & oPointGrid(i, 1), oPointGrid(i, 1))
Else
'Nothing
End If
End If
Next
'Convert the created dictionary of filtered points into an 2d-array
Dim ArrayFiltered(oPointGridFilteredX.Count - 1, 1) As Double
Dim ii As Integer = 1
For ii = 0 To oPointGridFilteredX.Count - 1
ArrayFiltered(ii, 0) = oPointGridFilteredX.Items()(ii)
ArrayFiltered(ii, 1) = oPointGridFilteredY.Items()(ii)
Next
'Place holecenters
Dim iii As Integer = 0
For iii = 0 To ii - 1
Dim oP = oSketch.SketchPoints.Add(oTG.CreatePoint2d(ArrayFiltered(iii, 0), ArrayFiltered(iii, 1)), True)
'MsgBox("oP " & ArrayFiltered(iii, 0) & " " & ArrayFiltered(iii, 1))
If Not (ArrayFiltered(iii, 0) = 0 And ArrayFiltered(iii, 1) = 0) Then
oHoleCenters.Add(oP)
End If
Next
'Loft Filter End
'Place holecenters
If oLoft = 1 Then Exit Sub
Endloft :
'MsgBox("Non Loft Code")
Dim P As Point2d = oEnt.StartSketchPoint.Geometry
Dim oSP As SketchPoint = oSketch.SketchPoints.Add(oTG.CreatePoint2d(P.X, P.Y), True)
oHoleCenters.Add(oSP)
P = oEnt.EndSketchPoint.Geometry
Dim oEP As SketchPoint = oSketch.SketchPoints.Add(oTG.CreatePoint2d(P.X, P.Y), True)
oHoleCenters.Add(oEP)
Next
End Sub
___________________________
