iLogic - Using model browser in rule editor causes 'Unhandled exception' error
Hello All,
I hope someone here can help with a rather worrying error message I received whilst writing an iLogic rule. I attempted to write a rule in an assembly comprising three parts. I had already successfully written two rules. The assembly is based on a skeletal model and is a very simple assembly comprising very simple parts. This is basically an exercise to familiarise myself with certain iLogic functions. When I attempted to expand a part within the assembly using the model browser in the rule editor, I received an error message stating "Unhandled exception has occurred in a component in your application...". If I click 'continue' I can return to the rule editor but the '+' next to the part I want to expand has disappeared.
However, if I write the rule by hand (because I have no choice) then the rule functions exactly as it should. I investigated this problem with three different versions of Inventor (2012, 2015 & 2016) and using two different PCs but the result was the same. After googling the problem I thought it might have something to do with the Windows .net framework so I updated it but this hasn't helped.
Any Ideas?
Chris
MegaJerk
Could you attach the problem assembly (in a low version of Inventor - 2012 if you have it and it's convenient) to the forums, so we can see if we can replicate the problem.
I've not encountered anything like this.
If my solution worked or helped you out, please don't forget to hit the kudos button :slightly_smiling_face:
iLogicCode Injector: goo.gl/uTT1IB
GitHub
