iLogic to Update Subassembly
I have a need to update all of the parameters in all of my sub assemblies as long as they have matching names. (For example, if the main assembly has a user parameter called "parameter1" any sub assemblies or parts that also have a user parameter called parameter1 should be updated) These sub assemblies may change, but I still want to have everything updated . I can update all my parts with the code below, but my assembly section of my code doesn't function as I am expecting. I feel like it should be updating based on my current knowledge, but I will admit that I am not iLogic Fluent. I have highlighted the area that isn't working. I feel like I should be able to get it to work with only one if loop, but I've gotten stuck.
TIA for any assistance.
Public Sub Main()
CopyUserParams()
iLogicVb.UpdateWhenDone = True
End Sub
Private Sub CopyUserParams()
If ThisDoc.Document.DocumentType <> Inventor.DocumentTypeEnum.kAssemblyDocumentObject Then
MsgBox("The active document must be an assembly.")
Return
End If
Dim asmDoc As Inventor.AssemblyDocument = ThisDoc.Document
For Each refDoc As Inventor.Document In asmDoc.AllReferencedDocuments
' Look for part documents.
If refDoc.DocumentType = Inventor.DocumentTypeEnum.kPartDocumentObject Then
Dim partDoc As Inventor.PartDocument = refDoc
Dim refDocUserParams As UserParameters = partDoc.ComponentDefinition.Parameters.UserParameters
' Add the assembly parameters to the part.
For Each asmUserParam As UserParameter In asmDoc.ComponentDefinition.Parameters.UserParameters
' Check to see if the parameter already exists.
Dim checkParam As UserParameter = Nothing
Try
checkParam = refDocUserParams.Item(asmUserParam.Name)
Catch ex As Exception
checkParam = Nothing
End Try
If checkParam Is Nothing Then 'do nothing
Else
' Update the value of the existing parameter.
checkParam.Expression = asmUserParam.Expression
End If
Next
Else If refDoc.DocumentType = Inventor.DocumentTypeEnum.kAssemblyDocumentObject Then
Dim partdoc As Inventor.AssemblyDocument = refDoc
Dim refDocUserParams As UserParameters = asmDoc.ComponentDefinition.Parameters.UserParameters
' Add the top level parameters to the assembly.
Try
checkParam = refdocuserparams.Item(asmUserParam.Name)
End Try
Else
End If
Next
End If
Next
End Sub
I solved my own problem. The issue was that I was calling out the inventor partfile. Working code below. This is intended to update all parameters in all files as long as they match.
Public Sub Main()
	CopyUserParams()
End Sub
        Return
    End If
                 Dim partDoc As Inventor.Document = refDoc
            ' Add the assembly parameters to everything.
                Try
                End Try
					Else
				End If
                Next
    Next
End Sub
'Original Code Copied from https://forums.autodesk.com/t5/inventor-customization/ilogic-push-all-assembly-user-parameters-to-parts/m-p/7961847#M83748
'Modified to not add a missing parameter and to update subassemblies instead of just parts
trevorauman
I was looking for a variety of solutions to this same thing and many resulted in faults and other problems. Then I recalled one of my co-workers doing something similar and he had a very simple bit of code.
'Define the open document
Dim openDoc As Document
openDoc = ThisDoc.Document
'Look at all of the files referenced in the open document
Dim docFile As Document
For Each docFile In openDoc.AllReferencedDocuments
'format  file name
Dim FNamePos As Long
FNamePos = InStrRev(docFile.FullFileName, "\", -1)
Dim docFName As String
docFName = Right(docFile.FullFileName, Len(docFile.FullFileName) - FNamePos)
Parameter.Quiet = True
Parameter(docFName, "Parameter1") = Parameter1
Parameter(docFName, "Parameter2") = Parameter2
Parameter(docFName, "Parameter3") = Parameter3
Next
iLogicVb.UpdateWhenDone=True
InventorVb.DocumentUpdate()
ThisApplication.ActiveView.Fit
 This will run just the listed parameters and it will go into each part. There were problems 10 years ago that didn't always push the parameters into some of the subpart and assemblies, but I have not run into that recently. If that is an issue we simply put the code in some of the subassemblies.
