iLogic To Round Dimension On Drawing
Alexrose1942
Alexrose1942
I need a dimension style that rounds up to next 5mm , in Autocad its part of the settings you can change but in inventor it still doesn't exist.
i thought maybe there's a way with iLogic Or through the 'API Object Model' that this can be done?
Hi Alex,
Hope my code will be helpful for you
Dim oDrawDoc as DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
Dim oDrawingDimension as object
For each oDrawingDimension in oDrawDoc.Activesheet.DrawingDimensions.GeneralDimensions
Dim oDimValue as Double
oDimValue = oDrawingDimension.ModelValue * 10
oDimValue = (Round(oDimValue/5))*5
oDrawingDimension.OverrideModelValue = oDimValue / 10
Next
Note: This will round of only the drawing driven dimension if you delete the dimension and repeat the dimension it will load the default dimension value again you need to run the rule.
Alexrose1942
@Anonymous wow that's a great code! ill give it few tests and see what improvements i can suggest.
