iLogic to Read Current View Representation in Part File
Hi All,
I'm looking for the iLogic code to read which view rep is currently active in a part file so that I can then perform a few mods to the part via IF statements. I can't however find a way to read the active view representation from existing snippets or forum posts.
Example....
Dim oViewRep as ??????????????????????
If oViewRep = "View1" Then Mods to part... Else Other mods to part....  End If
Any help on reading the existing view rep would be appreciated.
Sergio.D.Suárez
Hello, With this code you can read what is the view of active representation in your part or assembly.
Dim oDoc As Document = ThisDoc.Document
Dim oDef As ComponentDefinition = oDoc.ComponentDefinition
Dim ActViewRep As String = oDef.RepresentationsManager.ActiveDesignViewRepresentation.name
Dim ActPosRep As String = oDef.RepresentationsManager.ActivePositionalRepresentation.name
Dim ActLOD As String = oDef.RepresentationsManager.ActiveLevelOfDetailRepresentation.name
MessageBox.Show(ActViewRep)
 I hope it will be useful to develop what you need. regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Thank you for the code! This seems to work for an assembly but not for a part.
I get the following error:
Object variable or With block variable not set.
System.NullReferenceException: Object variable or With block variable not set.
   at Microsoft.VisualBasic.CompilerServices.Symbols.Container..ctor(Object Instance)
   at Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateGet(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack)
   at LmiRuleScript.Main()
   at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
   at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Ignore that!
Works for parts if I remove the positional and LOD lines since they are not available in an ipt.
Thank you for the help :slightly_smiling_face:
