ilogic to open BOM (Bill of Materials) in inventor ??
doug.johnston
doug.johnston
Good morning everyone,
I am looking for some code to automatically open the BOM inside an Assembly ??
We have an ilogic code that runs to calculate totals quantities based on materials / cut size / cut length.  After we run that code we open the BOM manually to review that the rule has done everything correctly.
I would like to automate the opening of the BOM.
Any assistance is appreciated.
Doug J
It's not easy maintaining this level of insanity !!!!!
bradeneuropeArthur
Dim c As ControlDefinition = ThisApplication.CommandManager.ControlDefinitions.Item("AssemblyBillOfMaterialsCmd")
c.Execute
Arthur Knoors
Autodesk Affiliations:
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
Curtis_Waguespack
Hi @doug.johnston ,
See this past post on this topic that has some info about opening to a specific tab and editing the BOM, etc.
https://forums.autodesk.com/t5/inventor-programming-ilogic/open-bom-on-the-right-tab/m-p/9317332#M10...
I hope this helps.
Curtis
