iLogic to Name Drawing Sheet as Sheet Number
I need help naming my sheets with the active sheets part number plus the sheet number. I have the part number portion working correctly but I cant get the sheet number portion to work. In the end I'm wanting my sheet name to look like "aaaaaab" (where as a=part number and b=sheet number).
Here is what I have so far:
SyntaxEditor Code Snippet
Dim oSheets As Sheets = ThisDrawing.Document.sheets
Dim oSheet As Sheet
Dim SheetNumber As Integer
For Each oSheet In oSheets
    oSheet.activate
    oModel = IO.Path.GetFileName(ActiveSheet.View("ISO").ModelDocument.FullFileName)
    'MessageBox.Show(oModel)
    oDoc = ThisDoc.Document
    SheetNumber  = Mid(oDoc.ActiveSheet.Name, InStr(1, oDoc.ActiveSheet.Name, ":") + 1)
    partnum = iProperties.Value(oModel, "Project", "Part Number")("SheetNumber")
    'MessageBox.Show(partnum)
    ActiveSheet.Sheet.Name = partnum
Next
JaneFan
Please try using following code:
Dim oSheet As Sheet
Dim SheetNumber As String
    oSheet.activate
    MessageBox.Show (Mid(oDoc.ActiveSheet.Name, InStr(1, oDoc.ActiveSheet.Name, ":") + 1))
    partnum = iProperties.Value(oModel, "Project", "Part Number")(Int(sheetnumber))
    MessageBox.Show (partnum )
    ActiveSheet.Sheet.Name = SheetNumber + partnum
Next
Jane Fan
Inventor QA Engineer
I'm getting a "1T" for sheet 1 and a "2S" for sheet 2's name. My part number is XXX-XXXXX-XX(sheet number here)
JaneFan
Sorry, I must have misunderstood your intention.
Please let me know whether this is what you need: Name of partnumber + Sheet.index.
Dim oSheet As Sheet
    oSheet.activate
    ActiveSheet.Sheet.Name = partnum + "-" + SheetNumber
Next
Jane Fan
That worked perfect, thank you!
Can you write me what exacly should be write instead "ISO". I'm trying diferrents names, but I get: 'Sheet.View: Not found draw's name 'ISO'.
It works, when you want to give same text from first sheet (Part number) for all sheets. Do you know how get text from Part number for each sheets separatly?
