Ilogic to get bounding box of assembly
Charlies_3D_T
Charlies_3D_T
Can someon help me to write a ilogic that when it's run it calculates the bounding box of an assembly? I would need this for shipping of assemblies.
Thank you !
raith-mb
Did you already check theRangeBox:
https://forums.autodesk.com/t5/inventor-customization/rangebox-without-workfeatures/td-p/5526317
It works good if the part/Assembly is alligned to X-Y-Z.
Otherways the RangeBox will be too big.
Roland
Charlies_3D_T
@raith-mb
Thank you for your link!
The problem is like you mentioned that if i have a hand rail then i get a to big bounding box thats why i was asking.
chandra.shekar.g
Autodesk Support
Autodesk Support
@Charlies_3D_T,
Please provide sample assembly to test and actual rangebox value (image). Please make sure that files are non confidential.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
