Message 1 of 1
iLogic to extract Sheet Metal Data
Hello.
I have been using a rule I found on this forum. I do not know who wrote it:
'Checks to see if kFactor, SheetStyle, FlatLength & FlatWidth parameters exist, and generates them, if not 'Source code for text parameter check 'Dim oPartDoc As PartDocument = ThisDoc.Document 'Dim oPartCompDef As PartComponentDefinition = oPartDoc.ComponentDefinition 'oParams = oPartCompDef.Parameters 'Dim oUserParams As UserParameters = oParams.UserParameters 'Try ' p = Parameter("MyParameter") 'Catch ' oUserParams.AddByValue("MyParameter","MyValue", UnitsTypeEnum.kTextUnits) 'End Try Dim oApp As Inventor.Application = ThisApplication Dim oParams As Parameters 'Dim oPartDoc As PartDocument = oApp.ActiveDocument Dim oPartDoc As PartDocument = ThisDoc.Document Dim oPartCompDef As PartComponentDefinition = oPartDoc.ComponentDefinition oParams = oPartCompDef.Parameters Dim oUserParams As UserParameters = oParams.UserParameters 'kFactor Try p = Parameter("kFactor") Catch oUserParams.AddByValue("kFactor", SheetMetal.ActiveKFactor, UnitsTypeEnum.kUnitlessUnits) End Try Parameter("kFactor") = SheetMetal.ActiveKFactor iProperties.Value("Custom", "kFactor") = SheetMetal.ActiveKFactor 'SheetStyle Try p = Parameter("SheetStyle") Catch oUserParams.AddByValue("SheetStyle", SheetMetal.GetActiveStyle(), UnitsTypeEnum.kTextUnits) End Try Parameter("SheetStyle") = SheetMetal.GetActiveStyle() iProperties.Value("Custom", "Sheet Style") = SheetMetal.GetActiveStyle() 'FlatLength Try p = Parameter("FlatLength") Catch oUserParams.AddByValue("FlatLength", SheetMetal.FlatExtentsLength, UnitsTypeEnum.kDefaultDisplayLengthUnits) End Try Parameter("FlatLength") = SheetMetal.FlatExtentsLength 'FlatWidth Try p = Parameter("FlatWidth") Catch oUserParams.AddByValue("FlatWidth", SheetMetal.FlatExtentsWidth, UnitsTypeEnum.kDefaultDisplayLengthUnits) End Try Parameter("FlatWidth") = SheetMetal.FlatExtentsWidth 'dArea Try p = Parameter("dArea") Catch oUserParams.AddByValue("dArea", 0, "ul") End Try 'FlatArea Try p = Parameter("FlatArea") Catch oUserParams.AddByValue("FlatArea", 0, "ft^2") End Try 'Forces update after rule runs iLogicVb.UpdateWhenDone = True
This rule functions well, as I only needed the 1st four values from the part. I now need the other two values, however the dArea and FlatArea parameters are not populating correctly. Both return zero values. I am not sure what the dArea value is actually supposed to be reporting.
I would like an explanation of what the dArea parameter actually is, and to see this rule return is two values:
- The actual flat pattern area, (not 'FlatWidth x FlatLength') disregarding any perforations, holes, etc.
- The flat area with all perforations.
I have attached a simple folded part. Using the Measure tool, Inventor calculates the flat area with hole as 416.230484254 in². Without the hole, this value is 444.504818136 in²
TIA
