Ilogic to count parts in subassembly
goran.nilssonRSJCU
goran.nilssonRSJCU
Hello
I have a top-assembly that consists of a large number of sub-assemblies. I want to go through all the sub-assemblies and look for a specific part number ( like iProperties PartNumber ="73265" ) and then return in which sub-assemblies that the specified part number is included in. How can I get in which sub-assembly that the specified part number is included?
JhoelForshav
Hi @goran.nilssonRSJCU
If the partnumber you're looking for is always a part you could try this rule :slightly_smiling_face:
Dim oAsm As AssemblyDocument = ThisDoc.Document
Dim oPnr As String = InputBox("Part number: ", "Enter part number", "PARTNUMBER")
Dim Msg As String = "Part exists in: " & vbCrLf
Dim oList As New List(Of String)
Dim partExists As Boolean = False
For Each oOcc As ComponentOccurrence In oAsm.ComponentDefinition.Occurrences.AllLeafOccurrences
	If oOcc.Definition.Document.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value = oPnr
		partExists = True
		Try
			If oList.Contains(oOcc.ParentOccurrence.Name) = False Then oList.Add(oOcc.ParentOccurrence.Name)
		Catch
			'Part is in top level assembly
			If oList.Contains(oAsm.DisplayName) = False Then oList.Add(oAsm.DisplayName)
		End Try
	End If
Next
If partExists = True
For Each oItem As String In oList
	Msg = Msg & oItem & vbCrLf
Next
MessageBox.Show(Msg, "Sub-assemblys containing part", MessageBoxButtons.OK)
Else
MessageBox.Show("Cant find part with partnumber: " & oPnr, "Sub-assemblys containing part", MessageBoxButtons.OK)
End If
JhoelForshav
@goran.nilssonRSJCU
This is probably better. This code searches for both parts and assemblies with the specified part number.
Then it returns a list of all the subassemblies (or top assembly) that contains the an occurrence with that part number.
It also counts how many of it exists in each subassembly :slightly_smiling_face:
Dim Pnr As String = InputBox("Enter partnumber: ", "Search for partnumber", "000000")
Dim oList As New Dictionary(Of String, Integer)
Dim Msg As String = "Component count in Assembly/Subassemblies: " & vbCrLf
Dim pNrExists As Boolean = False
For Each oDoc As Document In oAsm.AllReferencedDocuments
	If oDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Or _
		oDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject
		If oDoc.PropertySets.Item("Design Tracking Properties") _
			.Item("Part Number").Value = Pnr
			For Each oOcc As ComponentOccurrence In oAsm.ComponentDefinition.Occurrences.AllReferencedOccurrences(oDoc)
				pNrExists = True
				Try
					If oList.ContainsKey(oOcc.ParentOccurrence.Name)
						oList.Item(oOcc.ParentOccurrence.Name) += 1
					Else
						oList.Add(oOcc.ParentOccurrence.Name, 1)
					End If
				Catch
					If oList.ContainsKey("Top level assembly")
						oList.Item("Top level assembly") += 1
					Else
						oList.Add("Top level assembly", 1)
					End If
				End Try
			Next
		End If
	End If
Next
For Each oKey As String In oList.Keys
	Msg = Msg & oKey & " - " & oList.Item(oKey) & " st" & vbCrLf
Next
If pNrExists
	MessageBox.Show(Msg, "Found components", MessageBoxButtons.OK)
Else
	MessageBox.Show("None!", "Found components", MessageBoxButtons.OK)
End If
goran.nilssonRSJCU
@JhoelForshav Thank you for your reply. It worked well but I wonder if it possible to even find virtual components in subassemblies? In some subbassemblies have we added a couple of virtual components,
JhoelForshav
This should cover virtual components aswell :slightly_smiling_face:
	If TypeOf oOcc.Definition Is VirtualComponentDefinition
		If oOcc.Definition.PropertySets("Design Tracking Properties") _
			Else
			End If
			pNrExists = True
		End If
	End If
Next
		If oDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject
			For Each oOcc As ComponentOccurrence In oDoc.ComponentDefinition.Occurrences
						For Each parentOcc As ComponentOccurrence In oAsm.ComponentDefinition. _
							If oList.ContainsKey(parentOcc.Name)
								oList.Item(parentOcc.Name) += 1
							Else
								oList.Add(parentOcc.Name, 1)
							End If
							pNrExists = True
						Next
					End If
				End If
			Next
		End If
				pNrExists = True
				Try
					Else
					End If
				Catch
					Else
					End If
				End Try
			Next
		End If
	End If
Next
Next
If pNrExists
Else
End If
Moverano
What is the diferrence with the bill material?  In it you already see all the data such as the piece (part number) quantity
Vickimcl
@JhoelForshav
Love your code. Fast and easy.
I noticed sometimes the qty per assembly is not always correct, it seems to occur with phantom parts (?)
