iLogic To Add Pattern Into Another Pattern In Assembly
felix.cortes5K3Y2
felix.cortes5K3Y2
Hey forum,
I have two patterns and I am trying to add one pattern inside the other but I am unsure how to do this with iLogic. I think I have to make an object collection of the pattern that needs to be patterned again ("Pattern Two").
Here's how I've approached it so far:
	Dim oDoc As Document = ThisApplication.ActiveDocument
	Dim oAsmCompDef As AssemblyComponentDefinition = oDoc.ComponentDefinition
	Dim oOccPattern1 As OccurrencePattern
	Dim oOccPattern2 As OccurrencePattern
	Dim oObjCol As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
	Dim FirstPattern As String = "Pattern One"
	Dim SecondPattern As String = "Pattern Two"
	'add second pattern inside first pattern
	For Each oOccPattern1 In oAsmCompDef.OccurrencePatterns
		If oOccPattern1.Name = FirstPattern Then 'looks for the first pattern inside the assembly
			For Each oOccPattern2 In oAsmCompDef.OccurrencePatterns
				If oOccPattern2.Name = SecondPattern Then 'looks for the second pattern inside the assembly
					oObjCol.Add(oOccPattern2) 'adds the second pattern into a collection
					oOccPattern1.ParentComponents.Add(oObjCol)
				End If
			Next
E End If Next
Any help is greatly appreciated!
Felix
JelteDeJong
try this:
Dim occurrencePattern1 As OccurrencePattern = Nothing
Dim occurrencePattern2 As OccurrencePattern = Nothing
For Each oOccPattern In oAsmCompDef.OccurrencePatterns
    If oOccPattern.Name = FirstPattern Then 'looks for the first pattern inside the assembly
        occurrencePattern1 = oOccPattern
    End If
    If oOccPattern.Name = SecondPattern Then 'looks for the second pattern inside the assembly
        occurrencePattern2 = oOccPattern
    End If
Next
If (occurrencePattern1 Is Nothing Or occurrencePattern2 Is Nothing) Then
    MsgBox("Paterns not found")
End If
Dim oOccurrences As ObjectCollection = occurrencePattern1.ParentComponents
oOccurrences.Add(occurrencePattern2)
occurrencePattern1.ParentComponents = oOccurrences
Jelte de Jong
Blog: hjalte.nl - github.com
felix.cortes5K3Y2
Thank you Jelte
