iLogic Text Box in Sketch
mk92
mk92
i need to create a textbox in a sketch at specific coordinates. Is this possible?
Marco
rossano_praderi
Hi Marco,
this sample add a text within a sketch.
https://forums.autodesk.com/t5/inventor-customization/embossed-text-with-ilogic/m-p/5511400/highligh...
Bregs
Rossano Praderi
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
mk92
Works fine, thank you! But i have some problems to change the Font Size.
I tried:
 Dim oTextBoxes As TextBoxes
 Dim oStyle As TextStyle
            For Each oTextBox In oTextBoxes
                oStyle = oTextBox.Style
                oStyle.Font = "Chiller"
                oStyle.FontSize = 10
            Next
But it says:
Object reference not set to an object instance.
RodrigoEiras
Hi mk92,
I think you have to look for the property FormattedText if you want to override the text size for an specific TextBox.
I believe you may find this post helpful:
https://forums.autodesk.com/t5/inventor-customization/change-font-size-with-vb-net/m-p/5655174/highl...
I hope it helps!
mk92
Got it! Thank you!
