06:37 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I would like to suppress one of the bend feature of the part with multiselection. For example, Type A the bend will suppress; the bend feature active when Type B. However, my codes do not go well as since the bend is suppressed, the bend do not back to active status when Type A is selected.
MultiValue.SetList ("Type", "A", "B") ' ***Type B*** Feature.IsActive("Type B") = False Select Case Type Case A Feature.IsActive("Type B") = False Case B Feature.IsActive("Type B") = True End Select iLogicVb.UpdateWhenDone = True Parameter.UpdateAfterChange = True
