Ilogic suppression with multivalue went wrong
I would like to suppress one of the bend feature of the part with multiselection. For example, Type A the bend will suppress; the bend feature active when Type B. However, my codes do not go well as since the bend is suppressed, the bend do not back to active status when Type A is selected.
MultiValue.SetList ("Type", "A", "B")
' ***Type B***
Feature.IsActive("Type B") = False
Select Case Type
Case A
Case B
	Feature.IsActive("Type B") = True
	End Select
iLogicVb.UpdateWhenDone = True
Parameter.UpdateAfterChange = True
Sergio.D.Suárez
Hi, try the following ilogic rule. I attach a sample file
In this rule I show you another more secure access to the parameter.
Dim doc As PartDocument= ThisDoc.Document
Dim oCD As ComponentDefinition = doc.ComponentDefinition
Dim oType As String = oCD.parameters("Type").value
If oType = "A" Then Feature.IsActive("Type B") = False
If oType = "B" Then Feature.IsActive("Type B") = True
I hope this helps with your problem. Regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
